Honda S2000 Honda S2000
drivers seat removal on a 06'
Old Sep 27, 2010 | 05:09 PM
Robert O's Avatar
Default drivers seat removal on a 06'
I'd like to remove the seat assy so I can get the bottom re-upholstered. Will this cause the SRS system to trigger an air bag light or is the procedure simply a means of unbolting the seats and disconnecting the seat belt/snesor leads and the headrest speaker leads.Thanks in advance for any input.
PS,before posting this I did a search and came up with what was supposed to be explicit instructions.All it said was to remove the seat and that installation was the reverse of the removal procedure.Duuuuuhh.
Old Sep 27, 2010 | 08:41 PM
TsujenDB1's Avatar
Default Re: drivers seat removal on a 06'
Assuming you're not going to drive the car (driver seat) why would it matter if a airbag light came on? Also assuming if it did it would go back off when you put the seat back in
Old Sep 28, 2010 | 04:43 PM
Robert O's Avatar
Well that's just it.The assume part.Do you know for fact that I would not get a light after the seat was removed and re -installed if I disconnected the sensor leads. I'd heard tale that it could disrupt the system causing a light that would need to be dealer reset.If what I heard was wrong ,then that is the info I seek. One would think not...but in this case I simply don't know.If someone has actually done this before or has access to factory removal instructions and could pipe in ...it would be most helpful.
Old Sep 29, 2010 | 06:17 AM
White Smoke's Avatar
i my honda
Global Mod
I know it can lead to a light that needs to be reset if you turn the car on while the airbag is disconnected on newer models. Might be the same for the seat? To be sure, just disconnect the battery and your will be fine.
Old Sep 29, 2010 | 07:00 PM
Robert O's Avatar
Thanks for the heads up info White Smoke. I'll post back results once I've attempted the removal.Oh,and I'll make sure I disconnect battery leads before unplugging any sensors.
Old Oct 3, 2010 | 06:55 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
We removed my friend's 06 seats to install some red AP1 seats. No problems. Nothing to reset.
Old Oct 3, 2010 | 07:02 PM
Robert O's Avatar
Cool B serious. That's just the specific info I was seeking. Do you remember how many connectors besides the roll bar speakers you had to disconnect? Obviously I haven't tackled this job yet.
Old Oct 3, 2010 | 07:16 PM
B serious's Avatar
There are 2 plugs on the bottom of the driver's seat, IIRC. It's 4 bolts and 2 plugs. ANYONE with a wrench can do this. It took me literally 2 mins to get it out of there.
I don't think the roll bar speakers are plugged into the seat bottom, however. The roll bars are behind the seat...so that wouldn't make sense.
Unclip both plugs from their holsters. Then unplug them. Done.
2 12mm head bolts hold the front of the seats.
2 14mm head bolts hold the rear of the seats.
The passenger seat is a little more complex. But the driver's seat is a no brainer.
Old Oct 3, 2010 | 07:23 PM
Robert O's Avatar
Way cool. Thanks a bunch. I assume you removed it without disconnecting battery lead/s.
Old Oct 3, 2010 | 07:27 PM
B serious's Avatar
Yeah, I didn't disconnect the battery leads.
The weight sensor underneath the seat won't set off the air bag. It just tells the SRS system that there's someone in the seat.
The G sensor in the airbag unit or electricity through the airbag connectors will set it off. None of those are located in the seat.
I guess it couldn't hurt to unplug the battery. But I didn't bother.
Old Oct 3, 2010 | 07:36 PM
Robert O's Avatar
Thanks man. I appreciate your thorough explanation of the components removal instructions. I'll make sure and post back with my results when I do it. This will now prompt me to do it soon.
Old Oct 3, 2010 | 09:13 PM
B serious's Avatar
No problem. Good luck.
Angeles1262
Acura TL, RL & ZDX
Apr 24, 2017 11:09 AM
shoklid
Jan 11, 2010 07:54 AM
soberstan
12
Oct 22, 2004 12:01 PM
diluted
Jul 22, 2004 01:39 PM
dacaveman
Sep 11, 2003 08:34 PM
