H22 swap in 1995 Accord..Runs but won't start by itself help!!!
Old Sep 27, 2010 | 04:31 PM
T9U4ReBgO's Avatar
Default H22 swap in 1995 Accord..Runs but won't start by itself help!!!
Just did a H22a4 swap into a 1995 accord. Runs great, drove the car down the road w/o any problems. Just will not start on its on, has to have starting fluid to be able to crank.
Any ideas?
Old Sep 27, 2010 | 07:32 PM
phootbag's Avatar
Default Re: H22 swap in 1995 Accord..Runs but won't start by itself help!!!
So, you're saying the car won't crank unless you give it starting fluid?
That's like saying "The apple fell up into the tree".
Old Sep 28, 2010 | 05:13 AM
T9U4ReBgO's Avatar
That's what I'm saying.
Old Sep 28, 2010 | 05:50 AM
GhostAccord's Avatar
H22A4 (OBD2) into a 95 (OBD1), how did you wire up the CKP & TDC sensors?
Old Sep 28, 2010 | 07:27 AM
rash's Avatar
Are you 100% positive the timing belt is on properly? Sounds like you're a tooth off or so. I remember my first h22 swap, and I ended up with the same problem.
Old Sep 28, 2010 | 08:17 AM
T9U4ReBgO's Avatar
The swap was in another obd1 shell before. No problems...
Old Sep 28, 2010 | 11:56 AM
OK then and problems now......... something was overlooked!
TDC & CKP???
Old Sep 28, 2010 | 07:43 PM
rash's Avatar
Have you tried cracking the throttle a bit by pressing the gas while attempting to start it?
Old Sep 29, 2010 | 03:10 AM
T9U4ReBgO's Avatar
Only codes now are IAT, engine coolant temp, and vtec.
Yes tried to prime the system a few times and cracking the throttle.
Old Sep 29, 2010 | 05:10 PM
rash's Avatar
You know what? I had a similar issue with an ECT before. It was causing impossible cold starts. Motor wouldn't start until the coolant temp was warm. Turns out it was a malfunction in the ECT. Are warm starts possible without the starting fluid?
Old Sep 30, 2010 | 05:19 AM
T9U4ReBgO's Avatar
No warm starts need startin fluid too.
Old Oct 1, 2010 | 02:09 PM
T9U4ReBgO's Avatar
Bump
Old Oct 3, 2010 | 05:18 PM
T9U4ReBgO's Avatar
Need help guys.
Old Oct 4, 2010 | 01:56 PM
rash's Avatar
Try a different ECU?
Old Oct 6, 2010 | 03:58 PM
T9U4ReBgO's Avatar
Tried the stock ecu and the chipped p28 with h22 basemap.
Old Oct 6, 2010 | 06:36 PM
Have you fixed the IAT, ECT and VTEC codes?
Did running the stock ECU throw any different codes?
Old Oct 12, 2010 | 02:28 PM
rash's Avatar
I would definitely fix any CELs before trying to diagnose a problem like this. It's the only way...
Old Oct 12, 2010 | 05:30 PM
nus_dogg's Avatar
Sounds like a fuel problem or fuel flow isn't sufficient.
tizzle4rizzle
Mar 7, 2012 06:43 PM
tizzle4rizzle
Mar 7, 2012 06:33 PM
buffgsr
May 5, 2010 05:02 PM
mugenaccord92
Feb 9, 2008 01:37 PM
95accordh22a
Mar 17, 2005 06:31 PM
