Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Sqeaking Clutch Master
Old Sep 27, 2010 | 01:03 PM
nothome17's Avatar
Default Sqeaking Clutch Master
is it a norm for the clutch master cylinder to sqeak? I've had this replaced about 2 times now. Once at 50k and now at 129k. It was pretty bad this time so i had it replaced. Now I got it back and its better but still hear a sqeak when I press the clutch.
Old Sep 27, 2010 | 01:43 PM
bryse68's Avatar
Default Re: Sqeaking Clutch Master
is it from the clutch master cylinder or the transmission? there is a squeek if the clutch fork pivot is not lubricated. the grease on the clutch fork pivot dries. unfortunatly the safest way to apply grease to that is removing the transmission...
Old Sep 27, 2010 | 03:10 PM
nothome17's Avatar
I'm guessing its from the Clutch Master and not the transmission.
Old Sep 27, 2010 | 04:43 PM
bryse68's Avatar
are you replacing it with oem units?
Old Sep 27, 2010 | 10:39 PM
aeon's Avatar
It's a common problem with the TSX. It's the master cylinder piston rod you just need to keep it lubed up. Over time it wears off and starts to squeak/click.
Few threads where you can read more about it.
http://www.tsxclub.com/forums/1st-ge...tch-sound.html
http://www.tsxclub.com/forums/1st-ge...-clicking.html
http://www.tsxclub.com/forums/1st-ge...ng-clutch.html
Old Sep 28, 2010 | 09:54 AM
nothome17's Avatar
Yes sir.. all OEM parts. Replaced twice almost every 50k.
Old Sep 28, 2010 | 04:39 PM
aeon's Avatar
Yes sir.. Keep the piston rod lubed up.
Old Sep 30, 2010 | 11:06 AM
nothome17's Avatar
But I just had the clutch master replaced and its still creaks. What a waste of money.
ohsnapzafingcu
May 16, 2011 04:30 PM
perseverance
Dec 29, 2006 04:47 AM
b16a4
Nov 18, 2006 11:04 AM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
