2 wire to 3 wire iacv
Old Sep 27, 2010 | 09:45 AM
streethonda's Avatar
Default 2 wire to 3 wire iacv
I just put a d16 out of a 99 civic into a 93 civic, I'm having trouble wiring the iacv. I have searched everywhere just can't seem to find it? I have the car running and it's giving a cel 10 and 14.
Here is how I have it set up
D16-->obd1 harness-->p06
For the iacv I took out the orange wire and wired the other 2 wires to the harness. Tried switching them with no luck if someone can help that would be great!
Thanks
Old Sep 27, 2010 | 10:05 AM
EE_Chris's Avatar
Default Re: 2 wire to 3 wire iacv
An ECU that controls a 2-wire IACV will NEVER control a 3-wire IACV and vice-versa. They may share the same acronym and provide the same function, but HOW they provide it is totally different between the two.
Old Sep 27, 2010 | 10:13 AM
boogienights's Avatar
view the images, it should help
http://hondaswap.com/swap-articles/o...-2-wire-47169/
Old Sep 27, 2010 | 11:04 AM
H22AFerio's Avatar
if you have the old IACV just swap them they interchange.
Old Sep 27, 2010 | 11:26 AM
HondaPartsHero's Avatar
Technical Hero
reuse the manifold off your old d15, you can't use the 3 wire IACV
Old Sep 27, 2010 | 12:25 PM
I might as well use the obd2b ecu? Just buy a harness rather then converting my manifold?
Old Sep 27, 2010 | 12:57 PM
94EG8's Avatar
Seagull Management
No, that OBD2 ECU is going to look for a bunch of other stuff you don't have. Its much easier to just swap the intake manifold.
Chaosgrunt
Mar 13, 2019 06:23 PM
xKING239x
Mar 29, 2013 10:03 AM
halfkoreanboy
Nov 2, 2010 11:15 AM
Rodzknight
17
Feb 27, 2008 09:06 AM
9281hatch
Sep 11, 2006 12:18 PM
