head porting...
If your replacing your guides your machinest is the one the controls if everything is centered up .By the picture i dont see what your asking nothing is done but a little port and polish work nothing that controls were the valve guide sits? On alot of race heads they grind out all the valve guide that comes out of the head so that only tthe valve is restricting air . Im not sure if that helps any just ask your machinist he should be able to answer what ever your asking. He is the one putting the guides in.
OP, if done correctly, machining down the valve guide boss can improve flow
GarageAlchemist
Jun 28, 2006 07:13 AM
