91 teggy does not start all the time
My integra will start after i try cranking it for a while. but it feels like it about to turn off. when i press the gas pedal it start to choke and most of the time it turns off..............
After its off i try to start it and it wont go........
I replaced the t-belt,waterpump... what can it be.
Timing, coil, ICM, PGM-FI Main Relay, fuel pump, any one of them, even the ign. switch or defective fuses.
You need to narrow things down a bit.
I would start with the basics, timing and fuel pressure check, if good, I would do a compression test.
Both the PGM-FI Main Relay and the ign. switch on a G2, [older Honda/Acura] can be an issue...
http://www.tegger.com/hondafaq/mainrelay.html
http://www.visualimpressions.ca/switch/ recall is only back to 97, but problem exists on pre 97 Honda/Acura.
http://techauto.awardspace.com/ignitionswitch.html 94
well my da did this to me all the time until i replaced the main fuel relay.about 50 bucks. that did the job never had a starting problem with my da again
Ha ha ha! This is a little embarrassing, but in my 93 the main fuel relay was giving me problems only when it was hot outside. So i took it out and put it in the fridge for a while. It worked. ha ha.
i replaced the fuel relay. A while back.the thing is that it when I don't mess with for a
Days it will start up cool. The problem is that it spuder. And wants to turn
Off , most of the time it those turn off and it won't start and if it those start
It runs like ****.
It runs like ****.
NemesisVette
49
Jan 3, 2013 12:37 PM
skirrrt
14
Nov 6, 2008 09:48 AM
