no crank
Old Sep 26, 2010 | 05:28 PM
wesk18's Avatar
Default no crank
my 95 accord manual trans wont start, only clicking sound when i turn the key, i have a new battery on my car, i replaced the ignition switch, the only way to make the car start is by jumping my battery positive side to the small terminal on the starter solenoid.
Old Sep 26, 2010 | 06:00 PM
phootbag's Avatar
Default Re: no crank
Voltage drop the starter. If you are hearing it click when you turn the key to start you've either got a bad connection or a bad starter. Most likely.
Old Sep 26, 2010 | 06:13 PM
bseriescrxsi's Avatar
bad connection between ignition and starter the small terminal is the power signal from the ignition
Old Dec 5, 2010 | 06:30 PM
wesk18's Avatar
i have a kill switch on the wire that goes from the key to the starter, it sometimes starts, can the kill switch relay be causing it to not have the correct current pass through and do it need a resistor?
Old Dec 6, 2010 | 11:06 PM
wesk18's Avatar
i went to check my kill switch relay i notice sparks coming out from this relay, sometimes it happens because i could hear it, its a denso 056700 8570, can this be the fault
apm
10
Mar 30, 2013 08:57 PM
carve
Sep 12, 2009 09:35 PM
Scud
Dec 19, 2007 11:28 AM
EG6-SIRII
Jan 12, 2007 01:50 PM
