blowby ls vtec 400+whp pic
Old Sep 26, 2010 | 12:56 PM
TeggieeTuner's Avatar
Default blowby ls vtec 400+whp pic
running the hoses off the back of the block straight to a catch can. open breather on valve cover.
i have 5w-20 mobil clean 5000 in it and last night raced a cbr 600rr, turbo porsche, and 06 mustang gt on a 175 shot.
beat all 3 but was shooting oil out of the breather on the catch can like crazy, but according to my dipstick used no oil? and only smoked on deceleration after i push the clutch in, it smokes for sec then stops, this is wierd...
the corner of my car where the catch can is is COVERED!
Old Sep 26, 2010 | 01:50 PM
blackeg's Avatar
Default Re: blowby ls vtec 400+whp pic
for the love of god put a dumptube on that wastegate asap.
as for the blowby, my can fills up as well. do you have a baffle in yours to help keep the oil in as its coming out under load?
if you are concerned about motor health, check your plugs for detonation, then do a compression and if needed leakdown test.
other factors...
what ptw tolerence was the motor assembled with?
what are the ring gaps?
how does the tune look as far as afr and total timing?
5w-20 is relatively thin oil. do you run a restrictor?
Old Sep 26, 2010 | 02:13 PM
Lewy. Dee Ayy's Avatar
iv personally seen nothing but issues with venting the block ONLY...maybe try venting the valve cover also...
Old Sep 26, 2010 | 02:26 PM
other factors...
no baffle that i know of, its an endyne can?
hell i dont remeber the specs on the motor when i built it, it was in spec, egale h beams and weisco 8:8:1 pistons .40 over so its 82mm bore.
tunes it a little on the rich side, its pretty conservative, tuned by adam hopkins on ectune.
yes running 7/32 oil restrictor amd have over 80psi oil pressure in full boost and vtec.
is the valvoline race oil in 50wt too thick?
what will detonation look like white with little chunks out or something?
its open downpipe so i cant hear it if it is but it was tuned with a wideband.
Old Sep 26, 2010 | 06:31 PM
oooops catchcan was filled to the rim....lol been driving it for 3 months and never drained it...lol oops i feel very dumb....
why is the wastegate dump tube so important?
Old Sep 26, 2010 | 06:58 PM
boostedeg302's Avatar
you may be losing as much as 50+ whp by not running a dumptube that is routed under the oil pan. This is because the extremely hot gases from the wastegate are blowing directly into your turbo. The hotter the air, the greater the chance for detonation and less power produced.
Old Sep 26, 2010 | 08:44 PM
it aims up in the air??
i dont run a hood, so i dont see how it could do that
Old Sep 27, 2010 | 05:21 AM
Ok well then it probably isnt so bad of a problem. I bet that it would definitely help make a few more whp
Old Sep 27, 2010 | 07:50 AM
E85B18's Avatar
Just a dump tube man. You could at least ghetto rig one for $20
Old Sep 27, 2010 | 09:51 AM
per4mance's Avatar
WTF is that on the valve cover going to the manifold? I hope thats not a brace to keep the wg from falling off. If it is then you have some janky **** bro.
Old Sep 27, 2010 | 12:18 PM
blackeg's Avatar
its not just hot but very low in oxygen. think, all the o2 in the air should have been consumed in the combustion process, so now your motor is sucking in hot air with no oxygen.
ive personally seen dyno gains of 30+ hp with the addition of a dumptube
Old Sep 27, 2010 | 01:17 PM
CleanLikeJdm's Avatar
Hype-R Stalker
I think most people refer to that as an "Oil feed line".
Old Sep 28, 2010 | 12:11 PM
blackeg's Avatar
^^^ holy **** thats hysterical for some reason. i just figured people would be able to figure it out
Old Sep 28, 2010 | 12:16 PM
Muckman's Avatar
Moderator in Chief
Its not just the temp. Most of the oxygen in exhaust has been consumed. Doesnt make for good intake air. Dont be a ricer, just put a dumptube on it.
Old Sep 28, 2010 | 01:23 PM
Turbo-LS's Avatar
The fittings off the back of the block always tend to allow alot of oil to make it's way into the can. Looks like an enzyme setup I ran on years back and overflowed it every pass on the track. Best thing to do plug the holes and put two off the front of the valvecover and you should be good to go
Old Sep 29, 2010 | 04:34 PM
blackeg's Avatar
well i was using a z10 can that would fill every 2-3 passes with the block fittings. solution: i got the welder and some metal and made a larger catchcan, almost 1 liter in size. i can go much longer now without emptying it out
Old Sep 30, 2010 | 06:40 PM
sweet. thanks guys
Old Sep 30, 2010 | 06:46 PM
EmminoDaGreat's Avatar
That looks like the oil feed line not a brace. lol... motor looks pretty clean, get a dump tube, and I like the d series vtec solenoid
Old Sep 30, 2010 | 06:51 PM
racemycivic's Avatar
Sometimes you get a lot of blow by out of the back of the block. also 5-20 wtffff! never run a turbo motor on less then 10-40
Old Oct 2, 2010 | 12:29 PM
SAXON's Avatar
did you run a baffled fitting for the back of the block? i also weld in little metal baffles in mine, as well as baffle the catch can
Old Oct 2, 2010 | 01:33 PM
jetspeedz's Avatar
I'm surprised no one has mentioned this but not running a hood certainly affects your aerodynamics and your overall time. Never seen a reputable drag car without a hood, but hey that is just me.
Old Oct 2, 2010 | 01:43 PM
rat city rex's Avatar
Make a return line from your can to the front of your oil pan. And then it would also help if you went from your valve cover to your can instead of your block to can.
Old Oct 2, 2010 | 01:47 PM
attack666's Avatar
all the people i kno ran line from the back to the breather had their breathers filled.. the ones that got holes infront of the valve cover never had an issue with the breather.
try getting 2 holes infront.
Old Oct 3, 2010 | 09:09 AM
guy_from_nerk's Avatar
My car does the exact same thing and I am NA at the moment. I am running the go autoworks ss catch can (big bastard) then returning it to the block via speed theory fittings. I notice that when under WOT oil magically appears on backside of my motor. I have teflon taped the block fittings in hopes that was the cause, nope still leaks. I have less then 800 miles on the car and after initial startup the car was street tuned with 14.7 AFR across the power band. I might check my catch can to see if its full, but if its not what else could be causing this?
civicb1812345
Dec 23, 2013 08:36 PM
92integraVTECgsr
26
Dec 17, 2009 10:05 PM
94preludeguy
Feb 20, 2009 05:19 PM
ULTRAdC2
Jan 31, 2007 05:15 PM
b16vtecsol
Nov 1, 2004 07:48 PM
