oil going somewhere...
Old 12-23-2013, 04:54 PM
civicb1812345's Avatar
Default oil going somewhere...
ok so i just recently got a ls vtec hatch. i have had it for about 2 weeks and have put almost 3 qts of oil in it, i park in a garage and the are no oil spots, and it hardly even smokes blue. my old one smoked worse and didnt even burn that much.
only thin i noticed was the nipple on the valve cover where the line from the vc to the inake is supposed to be, there is just a tiny little filter.
Old 12-23-2013, 05:00 PM
Marvin1985's Avatar
Default Re: oil going somewhere...
It's not suppose to smoke! Why do people think Hondas naturally burn oil??? Compression test it 1st
Old 12-23-2013, 05:05 PM
i dont think they are supposed to, i was just simply explaining myself, ill do a comp test this week.
Old 12-23-2013, 08:20 PM
I never narc'd on nobody!
NotARaCist's Avatar
Before you get the motor warmed up for a compression test, open up your radiator, check your coolant level, and make sure it isn't contaminated.
Old 12-23-2013, 08:29 PM
no oil in coolant, already did a flush when i got the car, i should also note motor is a ls vtec. and no the oil line to the head does not leak
Old 12-23-2013, 08:36 PM
B_Swapped93's Avatar
Get under the car at look at the bottom/back spray it down with BPC and set it run a bit while on stands. but as said do a wet and dry test.
angryhillbilly
04-07-2010 02:05 PM
jmv38
03-24-2006 08:59 PM
B18PoweredCivic
05-10-2004 10:04 AM
bigslimdog
42
03-27-2004 03:02 PM
lakerschamp2000
01-26-2004 05:53 PM
Quick Reply: oil going somewhere...
