evaporator: how to remove need diagram or a write up
im removing my evaporator i dont have ac any more so this **** is usless. someone know of a write or something so i can get rid of this pain in the ***, got all the bolts i can see but it wont split so i know im missing something
I know, I was being sarcastic because you asked a question then answered it without at least explaining what you did so if someone else had this problem they could refer to it. That is what this whole site is about, right?
noone seemed to respond at all. And if you ever want to do it, feel free to ask.
All i did was pull the pass airbag, glovebox and its bar. Then pulled out the 4-6bolts i dont recall and removed the evap section. It looks harder than it really is, found out once i tackled it. Pulled apart the case leaving the styrofome and all that intact. Also dont break the clips that secure the 2 parts of the case. Removed evap and reverse the procedure. also installed the cf airbag delete tray and gutted the glovebox, but im def no the first to do that
Tampa75
Audio / Security / Video
Oct 14, 2018 06:02 AM
