Oil Seal on Y21 gear box
Hello, I have a Civic Eg9 with a B16a2 engine and a Y21 gear box. I have replaced the Oil Seal on the right side, but its still leaking from the seal araund the driveshaft area. Is there something that i have done wrong? I also replaced the driveshaft with a new one.
Problem solved, i had mounted the oil seal wrong. When you are mounting your new seal make sure that you dont press it all the way in. The seal should be mountet with some room between the bearing and the seal. The surface of the seal should be the same "higth" as the surface on the gearbox, if you understand what im trying to explain.
flyinga
Nov 24, 2004 12:56 PM
