Widest tires for EP3? Please help.
Old Sep 25, 2010 | 02:57 PM
square_1's Avatar
Default Widest tires for EP3? Please help.
Hey guys,
I am running a set of 17x7 in rims with a +42 offset (I think) on my EP3. It is lowered just under 1.5 inches.
I am currently running a 215/45/17 and haven't noticed any rubbing but I am looking to possibly go a little larger.
Do you guys know what you can run on an EP3?
Thanks
square_1
Old Sep 25, 2010 | 03:35 PM
tru3aznplayaz's Avatar
Default Re: Widest tires for EP3? Please help.
225 rubs..i think becuase i was really low..
Old Sep 25, 2010 | 04:12 PM
DaveSi677's Avatar
ya 225 is pretty much the limit... I know a few running 235 but they be rubbing a little.
Old Sep 25, 2010 | 06:48 PM
square_1's Avatar
Well I am rocking the 215s now, I will probably stick with those.
I know they work and so I will stick with those.
Anyone have an experience with the difference between a 40 series and a 45 series?
Old Sep 28, 2010 | 04:11 AM
dr.k20z1's Avatar
i think 215/45 is perfect for a 7inch rim, theres no point in going wider.
my 2c
Old Sep 28, 2010 | 05:43 AM
turboteg2nv's Avatar
Yes, I've had both 17x7 rims with 215/45 and 17x7.5 with 215/40 tires.
Obviously the thinner sidewall makes for a bumpier ride, but better control under hard cornering.
Old Sep 28, 2010 | 07:26 AM
Gtimportfanatic's Avatar
Friend of mine runs 245 up front and 225 in the rear with little to no rub.. with proper alignment u can run these setups with good offset wheels
Old Sep 29, 2010 | 12:50 PM
SHG_EasyE's Avatar
Wrd Dre
My 225's in the rear with 1.5 deg camber dont rub at all, and they are Dunlop Z1's which are just as wide as a falken Azenis in 235's. They are beefy *** tires and clear no problem with rolled fenders. Add an extra .5* camber and youll clear without rolling.
Up front I used to run a 235 azenis on a 17x9 +35 wheel with no rubbing at -1.8* camber. Me new setup Im running now is a 245 Dunlop Z1 on the same wheel, but I also added DC5R control arms which essentially pushed the wheels out another 3/4 inch. To clear now with the new setup in the front Im running -3.5* with slightly pulled fenders and no rubbing.
Its amazing how much wheel and tire you can fit up front, but the rear youre limited to a 225.
Picture for reference
Old Sep 29, 2010 | 02:49 PM
PiNoY Ep3 SI's Avatar
There are a few guys on epahtch that run 245's all around check out 27rock's car
http://www.ephatch.com/forum/showthr...27rocks-Period
Old Sep 29, 2010 | 04:57 PM
nahonda04's Avatar
Surje.motorsports
reverse stagger ftw!!
prolly doing 16x9 up front and 16x8 or 8.5 in rear next spring!!
vitrox
11
Jul 17, 2004 10:30 PM
z6
14
Feb 8, 2004 09:49 PM
outlaw racer
Apr 13, 2003 08:23 AM
2fstGSR
Oct 17, 2002 03:23 PM
JohnnyBoy
Mar 16, 2002 10:05 AM
