94 del sol built and boosted wanna rough estimate on what my whp will be
Old Sep 25, 2010 | 09:20 AM
SIKAZZDELSOL's Avatar
Default 94 del sol built and boosted wanna rough estimate on what my whp will be
i got a 94 del sol si will be fully built this yr i got crower rods je pistons 9-1 crower stage 2 turbo cams crower standard valves dual valve springs and titanium retainers skunk 2 cam gears 750cc injectors walboro 255 fuel pump skunk2 intake manifold got throttle body not sure how man mm has a 76 on it not sure thats the mm i put lsd in tranny stage 3 cluth 7 1/2lb flywheel 3 inch vibrant exhaust aem wide band now im not running any boost at the moment cause im not done and tuned but i wanna kno if there is anyone out there who might have a round about guess to what i should push????????thanks
Old Sep 25, 2010 | 10:14 AM
fv8s's Avatar
Default Re: 94 del sol built and boosted wanna rough estimate on what my whp will be
considering we have no clue what bottom end you have (im guessing an ls/gsr/b16 considering you said this..."crower stage 2 turbo cams") , what the exact turbo is, what head you are using and if its the stock port ect. , and how many pounds you are planning on running we can not give you any number. why would you make a post asking us how many whp your going to make? there are probably over 20 threads on here with the same setup as you with dyno numbers. use the damn search function
Old Sep 25, 2010 | 10:22 AM
decko's Avatar
150whp-800whp depending on the tune, turbo and how much boost.
lol.
Old Sep 25, 2010 | 10:32 AM
fv8s's Avatar
lol.
haha i really shouldn't have wasted my time and just wrote that ^^
BlueVxIDelSlo
Jan 31, 2013 09:27 AM
B17SolRide
12
Jun 27, 2012 11:15 AM
Nucking Futz
Aug 7, 2011 05:08 AM
tannerLSt
Feb 17, 2006 06:33 AM
