Del Sol Turbo Project
well the del sol i have now just isn't boosted enough for me, so in the last week i've decided to build a motor and boost the hell out of it, here is what i've picked up so far: HEAD :
97 B18b head , milled, freshly rebuilt stock: torn apart and installed:
Crower ValveSprings/Retainers
Crower Valves
Crower Stage 4 Cams (404's)
Head is being port matched with turbo manifold/intake manifold and being polished
AEM Cam Gears
Skunk2 Intake Manifold
Skunk2 70mm Throttle Body
STR Fuel Rail
Aeromotive Fuel Pressure Regulator
-8an Fuel Feed Line
1000cc Precision Injectors
BLOCK:
B18a block w/ Golden Eagle Sleeves, hot tanked/honed,bored out to 85mm
LS crank micropolished
85mm Wiseco Pistons 9:1 c:r
Eagle H-Beam Rods
OEM Honda Bearings
ARP Headstuds
85MM Cosmetic Head Gasket
TURBO KIT:
Precision GT35R .82a/r exhaust housing
Spoolin Performance StreetPower ramhorn/full race style manifold
Tial 38mm Wastegate with .9bar spring w/dumptube
Tial 50mm BOV
2.5in polished aluminum charge pipe
30x11x3 in. Front Mount Intercooler w/3in. inlets
OTHER:
GM 3Bar sensor
Walbro 255lhp High Pressure Fuel Pump
P75 Ecu tuned with Neptune , hopefully will have two new tunes pump/race gas
AutoMeter Boost Gauge
AutoMeter Pro-Shift Light
Pro1 Engine Torque Dampner
Energy Suspension Motor mount inserts
OmniPower Drag Suspension 12front/10rear
MSD 6A Ignition Box
MSD SS Blaster Coil
MSD Distrbuter Cap
HOPEFULLY i will be putting this in a JDM front integra shell i'm looking at!!!!! how sweet would that be
putting it in a EG HATCH!!!!
Modified by tannerLSt at 10:11 PM 1/23/2006
Modified by tannerLSt at 8:59 PM 2/4/2006
Modified by tannerLSt at 10:40 PM 2/9/2006
Crower Valves
AEM Cam Gears
STR Fuel Rail
-8an Fuel Feed Line
BLOCK:
Eagle H-Beam Rods
OEM Honda Bearings
ARP Headstuds
TURBO KIT:
Tial 50mm BOV
OTHER:
GM 3Bar sensor
MSD 6A Ignition Box
MSD SS Blaster Coil
MSD Distrbuter Cap
putting it in a EG HATCH!!!!Modified by tannerLSt at 10:11 PM 1/23/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">well the del sol i have now just isn't boosted enough for me, so in the last week i've decided to build a motor and boost the hell out of it, here is what i've picked up so far:
B18a block w/ Golden Eagle Sleeves, hot tanked,bored out to 85mm, freshly honed
85mm Wiesco Pistons 9:1 c:r
Eagle H-Beam Rods
ACL Bearings
ARP Headstuds
97 B18b head , milled, freshly rebuilt stock,(going to go with Crower valvetrain and 402t cams and probably skunk2 cam gears and a JG intake mani)
Precision GT35R 60trim .82a/r 4bolt exhaust housing
and still working on the rest of the set-up</TD></TR></TABLE>
sounds good. good luck with it. I'm transfering my built gsr-t from my coupe over to my del sol. but I'm debating keeping it simple with a stock sleeve built ls-t with similar headwork and a 60-1. as i said before. sounds good and good luck with it all. keep us updated with pics and such.
Eagle H-Beam Rods
ACL Bearings
ARP Headstuds
from my personal experience and researching the 402t's i wouldnt even worry about getting cam gears as their isnt much if any to be gained with these cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 »</TD></TR><TR><TD CLASS="quote">Looks like a really good setup... I think it will work very good... How much power are you looking to make?</TD></TR></TABLE>
thats a good question, guess it depends on how far we wanna push it on the dyno when tuning it i guess, i'd like to at least get 500whp , probably tune it to the max and then turn boost down, this is going to be a street driven car so won't need much more than 400whp for the street, will see the track plenty of times i'm sure
ordered a Spoolin Performance Manifold today and got a Tial 38mm Wastegate and Fluidyne 1/2 Size Radiator with Maradyne 12" slimfan, hopefully will be ordering crower valvetrain and cams very soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">i didnt know gt35r's came with an E housing...</TD></TR></TABLE>
precision and some other garrett distributors or whatever offer them with E housings.
took motor yesterday to have it put together, went by today to drop off some more parts and he's started porting and polishing it...looks good so far, ordered my valvetrain and head gasket today....will try to get pics of progress soon
thats a good question, guess it depends on how far we wanna push it on the dyno when tuning it i guess, i'd like to at least get 500whp , probably tune it to the max and then turn boost down, this is going to be a street driven car so won't need much more than 400whp for the street, will see the track plenty of times i'm sure</TD></TR></TABLE>
On a side note, for the power level you are wanting to make, may I suggest to look into a little better bearing... IMO, I used the acl's in a street car w/ 420 whp... and they took a beating... (they are a softer compound)... This was the only set of set of bearing's that I had used from them, so maybe there was a defect... I use the clevitte bearing... The disadvantages on using them, are they are made of a harder compound, so if you have any debree that ges into the oil galley and then into the bearing surface, it will grove your crankshaft a little... I have put a lot of power down with the clevitte bearings, and they have handled it with no problems... They always look good when I remove them.. (with wear)... Just a little info.... JAsen
On a side note, for the power level you are wanting to make, may I suggest to look into a little better bearing... IMO, I used the acl's in a street car w/ 420 whp... and they took a beating... (they are a softer compound)... This was the only set of set of bearing's that I had used from them, so maybe there was a defect... I use the clevitte bearing... The disadvantages on using them, are they are made of a harder compound, so if you have any debree that ges into the oil galley and then into the bearing surface, it will grove your crankshaft a little... I have put a lot of power down with the clevitte bearings, and they have handled it with no problems... They always look good when I remove them.. (with wear)... Just a little info.... JAsen</TD></TR></TABLE>
yeah i heard the acl bearing are good for drag cars that your gonna rebuild soon, i've been told by many many people that honda bearings are better, so i'm going with oem honda bearings....not using the acl's!!!!!!!
well i decided on the 404's , should have them in a few days...should have pics up soon of block which is assembled all ready and pics of the start of the port and polish job
just a small preview of what will be coming soon, not using that manifold though but hopefully something similar but better quality</TD></TR></TABLE>
Any person that builds there engine in there bedroom on a Harbor freight engine stand is ok in my book
Good luck to both of these guys on there engine build.
