For those about to ROCK! (I Salute you!!) (my first post in the Prelude forum)
Old Sep 19, 2002 | 05:50 AM
Nikos's Avatar
Default For those about to ROCK! (I Salute you!!) (my first post in the Prelude forum)
I have a 98 accord sedan LX 4 cylinder, 5 speed.
I would aprreciate any input:
I am looking for a h22A engine+trans. Once I find it, I will take my time to rebuild it till next summer. Then in June I will put it in the accord. My research is almost finished as far as the swap is concerned.
Please let me know your ideas about setups. I want to go N/A but I don't need anything more than 230-250 HP.
I have been reading the archives and some of you guys have crazy setups.
I do want a reliable engine and like I said I am not going to drag the car. I just want good N/A power. If I do go ahead and put in the type-s cams what else would be a good idea?
Thanks,
Nikos
thanks to areyouasian for the pics
[Modified by 2 B 4GO10, 9:52 AM 9/19/2002]
Old Sep 19, 2002 | 06:00 AM
satan_srv's Avatar
Default Re: For those about to ROCK! (2 B 4GO10)
Do you mean at the crank? getting 230whp on an H22 N/A is tough. At least in a prelude anyways..
Old Sep 19, 2002 | 06:01 AM
Nikos's Avatar
Default Re: For those about to ROCK! (satan_srv)
Yes the crank!!!. Just 20-30 HP more than stock.
[Modified by 2 B 4GO10, 10:39 AM 9/19/2002]
Old Sep 19, 2002 | 06:36 AM
laughinxxx's Avatar
New User
Nope.. the wheels. Just 20-30 HP more than stock.
You say 230 whp and then you say just 30 more hp than stock. H22As put down anywhere from 160whp-165whp in most instances. It takes a well tuned 75 shot of nitrous to get up to 230whp. Right now I have 217 whp and an ungodly 10.5 AF ratio. 230 whp is going to be stretching it. You might want to start looking into high compression stroker kits or plan on boring some Golden Eagle sleeves out for another tenth liter or two.
Old Sep 19, 2002 | 06:39 AM
Nikos's Avatar
Default Re: For those about to ROCK! (laughinXXX)
Sorry my bad
I mean at the crank!!!!! Sorry.....
Thanks though!!!
Old Sep 19, 2002 | 06:50 AM
satan_srv's Avatar
Yeah okay so 230 at the crank is still a little tough. I'll estimate that at 180-185whp
That will be tough to hit with just bolt ons. You'll need all of them
Generally I would say you need higher compression (11:1+) to hit 190+ if you're NA
[Modified by satan_srv, 10:51 AM 9/19/2002]
Old Sep 19, 2002 | 06:55 AM
laughinxxx's Avatar
New User
Yeah okay so 230 at the crank is still a little tough. Generally I would say you need higher compression (11:1+) to hit 190+ if you're NA
Type S pistons, yummy.
Old Sep 19, 2002 | 08:26 AM
GAperformance's Avatar
New User
Get a JDM H22a(Higer compression), AEM CAI, Greddy Header, Any Decent Exhaust. Cam gears, pulleys, and VAFC and you should be almost there. Throw some cams on there and you will defintely hit your goal.
Old Sep 19, 2002 | 08:57 AM
CD8's Avatar
CD8
Default Re: For those about to ROCK! (bkw97lude)
one day:
12:1
golden eagle block
portflow head; stage 3 cams
everything p&p
all the bolt ons of course, and if that doesnt work... R&D here i come!
Old Sep 19, 2002 | 07:40 PM
Boostless97Lude
Guest
Posts: n/a
just buy a Type S swap, 220 HP, at the crank, already, then all you need is a good intake, header, and a full cat-back exhaust and your set. maybe put a 50 shot on it for good measure.
Old Sep 19, 2002 | 10:06 PM
piotrush's Avatar
Is that with spray, or just motor? If its just motor, what do you have in there?
Old Sep 19, 2002 | 10:27 PM
laughinxxx's Avatar
New User
Default Re: For those about to ROCK! (piotrush)
No that's on the bottle. I wouldn't be driving around town with a 10.5 AF. As far as mods that is just ignition stuff, short ram intake, greedy SP, and an untuned 75 shot.
jsnappdaddy88
Nov 7, 2014 10:10 PM
wwong510
Oct 4, 2007 10:48 AM
86ACCORDDIPPIN
Jan 14, 2005 11:22 AM
Bludger
Jul 2, 2004 08:27 AM
00CIVICwB18C1
Nov 12, 2002 07:18 PM
