d16y7 with a 16a6 head?
Old Sep 24, 2010 | 10:40 PM
jdm.swift's Avatar
Default d16y7 with a 16a6 head?
d16a6 with d16y7head into a 1990 ef
my boi got the head for me i just need the motor...
my question is will everything match up/bolt up plug&play tranny/dizzy/ecu wire harness?
currently stock d15b2 with aftermarket header no intake!
Old Sep 24, 2010 | 11:18 PM
prelude182's Avatar
Default Re: d16y7 with a 16a6 head?
if youre running a dpfi system you will want to change it to mpfi and obdo mpfi dizzy. unless its already converted. pretty much everything is bolt up plug and play with d-series. im not sure about the timing belt tho.
Old Sep 24, 2010 | 11:21 PM
jdm.swift's Avatar
thanks.
Old Sep 25, 2010 | 01:23 AM
661rex89si's Avatar
you need to use one y8 head stud the rest can be a6/z6 head studs. the head swap will result in a bit of a increase in compression which should give it a bit of pep with the right IM should be good.
Jturpen569
Feb 25, 2018 06:27 PM
Miho1269
Aug 9, 2012 03:25 AM
Mugen112
May 8, 2009 05:47 PM
Merlin1068
May 6, 2003 07:41 PM
15scivicredline
Mar 23, 2003 11:16 AM
