dpfi-mpfi question
Old Sep 24, 2010 | 08:41 PM
repingjdm's Avatar
Default dpfi-mpfi question
ok so im doing another mpfi swap got it all set up and im using injectors off a z6 which dont need the require resistor box right? if so then what do i do with the 4 yellow/black wires left over? or do i have to go grab a resistor box? this is going on my girl crx sohc zc.
Old Sep 24, 2010 | 11:36 PM
TalonC1's Avatar
Default Re: dpfi-mpfi question
Posting for the answer. I've been doin research and im still stumped on this one
Old Sep 25, 2010 | 06:42 AM
repingjdm's Avatar
if you find out out plz tell me lol any1 ????
Old Sep 25, 2010 | 06:46 AM
Oedwards's Avatar
I've only did one dpfi to mpfi swap. If you have obd1 injectors I think you are suppose to run a obd1 ecu. When I do any swap I try to leave the car as original as possible ex: stay obd0 and keep the box.. but this won't work for everybody.
Old Sep 25, 2010 | 08:05 AM
repingjdm's Avatar
not so true you dont have to use a Obd1 ecu to run obd1 injectors.i dont have the box so thats the only reason im using the z6 injectors since i dont have it
Old Sep 25, 2010 | 10:32 AM
D16SiHatch's Avatar
just take the 5 wires that go to the box and solder them together.
Old Sep 25, 2010 | 10:52 AM
repingjdm's Avatar
ya but i thought i didnt need the box if im using z6 injectors? i found a box so just wire the z6 injectors to the box?
Old Sep 25, 2010 | 10:53 AM
repingjdm's Avatar
using a pm6 ecu fyi
Old Sep 25, 2010 | 01:28 PM
hatchet_honda's Avatar
pretty sure obd1 injectors need an obd1 ecu. no resistor box obviously.
Old Sep 25, 2010 | 06:08 PM
D16SiHatch's Avatar
you don't need the box, i said solder the wires together that would go to the box. one of the wires is 12v power, and the rest go to each injector. since you are not trying to drop the voltage you only need to solder/connect all 5 of the wires to eachother.
they don't. whether an injector is saturated or peak/hold means nothing to the ecu. the only thing that matters is you use a box if using peak/hold and delete the box if using saturated.
Old Sep 28, 2010 | 04:37 AM
singlecamsaint's Avatar
x2 it works i believe the a1 -a7 are actually the injector grounds and the a15 is the 12v source, otherwise it would have to constantly switch off one ground it kinda makes since to have 4 different grounds and one power
also, since the obd I injectors are high impedance and not low impedance like the obd 0 there isnt a need for the resistor box because the injectors do the resisting not the box
Last edited by singlecamsaint; Sep 28, 2010 at 04:43 AM. Reason: left out something
travishoward
Aug 12, 2010 05:41 PM
thundernutz
Sep 8, 2009 10:27 PM
ef9ontime
May 28, 2006 01:23 PM
nevin
Aug 16, 2005 03:21 PM
