engine smokes from breather what is this?
Old Sep 24, 2010 | 06:43 PM
mike333's Avatar
Default engine smokes from breather what is this?
ebay turbo 97 ls, after the car warms up it smoke white smoke out the breather on the valve cover, what does this most likely mean? also when i was driving in fifth gear the other day for about a 4 or 5 mile period the clutch pedal just dropped to the floor and gave me barely any play to shift, but once i shifted gears continiously again it was all the way up and stiff like it was suppose to be, what does this most likely mean?
Old Sep 24, 2010 | 07:08 PM
roco12's Avatar
Default Re: engine smokes from breather what is this?
Wow great. . .
Old Sep 24, 2010 | 08:09 PM
Spawne32's Avatar
check your oil and see if it turned milky, i wouldnt be surprised if you blew a head gasket
Old Sep 24, 2010 | 08:23 PM
mike333's Avatar
yea that would probably explain why im experiencing an empty radiator and overheating after a 30-45 minute drive wouldnt it?
Old Sep 24, 2010 | 08:26 PM
teggi's Avatar
yes, check thermostat too. get the head checked too while its off
Old Sep 24, 2010 | 08:27 PM
mike333's Avatar
i would love to get the head checked but im stationed in korea no real mechanics around here maybe if u could explain what to look for i could check it myself, love that kinda **** anyways
Old Sep 24, 2010 | 08:39 PM
teggi's Avatar
get a straight edge, and a feeler gauge. i'm not sure what the specs should be on a stock head tho
Old Sep 25, 2010 | 09:23 AM
fcm's Avatar
fcm
Old Fart
I have to agree, HG, pull the head and replace the head gasket.
You said, "im stationed in korea" I assume in the military, if so, my bet is there is a hell of a good machine shop on your base, even the mechanics at the car pool could probably check the head for warpage, that said, if a straight edge shows true, your probably OK with a new HG. 94
benjamin
Jul 2, 2022 11:49 AM
N0r420cal
13
Aug 25, 2013 01:18 PM
micos95eg
Jan 5, 2009 07:33 PM
DreamCatcher
Nov 27, 2005 02:28 PM
