Fuel gets to the rail but injectors wont spray
Old Sep 24, 2010 | 03:57 PM
Lmgrcivic's Avatar
Default Fuel gets to the rail but injectors wont spray
Im getting fuel to the injector there is fuel in the rail. I pulled the rail off and the injectors out of the manifold and they wont spray. the injectors are brand new
Old Sep 24, 2010 | 04:24 PM
delsolproblems's Avatar
Default Re: injectors wont spray
The ECU uses the sensors in the distributor (TDC, CYP, etc) to determine when to spray the fuel. If one isn't working correctly, the injectors either won't spray or will spray at the wrong time. Check the resistance of these sensors and make sure they are in spec. When did the problem start?
Old Sep 24, 2010 | 04:30 PM
Lmgrcivic's Avatar
well Im just putting the car back together but it worked before the tear down
Old Sep 24, 2010 | 05:02 PM
Most likely it will be a broken circuit somewhere- something not connected or connected wrong. You can set a meter to resistance and probe between things like the distributor sensors or injectors and the ECU. No resistance is a clean connection and infinite resistance is a broken circuit. Search for a pinout diagram for your ECU to see which wires go where.
You might also run a quick spark check just because both the spark and injectors being out would point to more specific problems. Disconnect a plug wire, hold the plug end 1/4" or so from grounded metal and have someone crank the engine while you watch for a spark arcing to the ground.
Old Sep 24, 2010 | 05:48 PM
Former User's Avatar
Does the starter crank the engine. The injectors will only spray if the engine is turning.
Do the injector clips get battery voltage?
Any CEL codes?
Old Sep 25, 2010 | 12:35 PM
Lmgrcivic's Avatar
Default Re: Fuel gets to the rail but injectors wont spray
the motor is cranking it just wont turn over
Lmgrcivic's Avatar
also wouldnt know if its putting any codes the car is run off AEM
Old Sep 25, 2010 | 01:33 PM
tundra2000's Avatar
Check all the grounds, i had the same problem with my d16z6, it happen to be the ground on the thermostat housing.
Old Sep 25, 2010 | 04:25 PM
Lmgrcivic's Avatar
aight i will check grounds. also i have checked for spark like delsolproblems said earlier. it has spark
mikester1222
17
Apr 18, 2008 07:32 PM
90civSi
Jun 22, 2006 12:23 PM
Jmunk
Feb 17, 2006 10:09 AM
shreddinryguy
Jun 26, 2005 01:28 PM
allmotor.net
Sep 27, 2004 11:57 AM
