HELP! My pulley fell off!
as the title says the pulley that runs my ac and power steering fell off while i was driving. so how the hell do i put it back on. these are the parts i picked up from the road, am i missing something?
[Modified by H2OCivic95, 3:19 PM 9/20/2002]
your crank pulley fell off! holy crap.
it looks like you've got the pulley, bolt, and two of the three belts
AC, PS, Alternator
I dont know the torque spec of the crank pulley bolt, so I guess I'm not that much of a help
AC, PS, Alternator
is that the crank pulley? you will probably need to get a new key. it goes in a little groove on the crank and lines up with a little groove on the inside of the pulley. it makes sure that the pulley is put on in the correct position relative to the crank.
yes, get a new woodruff key. When the key is in, you can't put the pulley on wrong. Be sure that bolt is torqued to about 125-130lb/ft. Replace all those belts while you're in there too.
got it fixed, a buddy of mine that works at acura helped me out. He told me that there was a recall on this, so for any of you with 95's should check in on it just in case.
