stripped header bolts help
k so whoever had the car before me stripped out 2 of the holes where the bolts go to bolt the header on, they tighten very little then spin, u cant pull them outby hand, i was wondering if i can use studs and jb weld them, in if that will work im afraid to use a kit where u drill then tap ay help is appreciated
Re-tap the threads in the same thread pitch, its not overly complicated. Sometimes the biggest task is trying to find a way to spin the tap, as the handles in the kits wont work on tight spaces. Just make sure to go slow and use WD40 or old engine oil for lubrication, as cast aluminum is easy to strip or overly deform.
You might just end up having to drill and re-tap for a bigger stud/bolt however, worst case.
miahmouse
Aug 17, 2006 07:27 AM
