Honda S2000 Honda S2000
I just bought a s2000 but i need some help to get it back on the road
Old Sep 23, 2010 | 01:37 PM
Navy_CRX's Avatar
Default I just bought a s2000 but i need some help to get it back on the road
Like the title says i just bought a 2000 s2000 for 5k. Bretty good deal considering it has a willwood 6 piston big brake kit koyo radiator BC type RS 32 way adjustable coilovers glass window soft top (does have 3 patches but was assured that it dosent leak) HKS Dual exhaust dual piller with Delphi gauges AEM intake DC sport header a cabon fiber rear lip and cooling plate. The body and interior are not the greatest but has 75k on the engine. Reason i got it so cheap is the differintial grinds real bad when i try to move it. Does this mean the diff is shot. If so is it possible to rebuild it. Or maby someone here has a good one for sale. Ill post pics when i can.
Thanks for the help in advance
Eddie
Old Sep 23, 2010 | 02:29 PM
wrXtian's Avatar
Default Re: I just bought a s2000 but i need some help to get it back on the road
i've seen differentials sell on ebay. i think they range around $500
btw congrats on your purchase. sounds like it could work out to be a good deal.
Old Sep 23, 2010 | 02:48 PM
Navy_CRX's Avatar
Hope fully. Any chance someone knows of a diy rebuild thread for the diff. Was reading about changing the diff gears. Where is a good place to get 4.4s??? Im a competent mechanic and would rebuild the diff if possible.
Thanks again
Eddie
Old Sep 23, 2010 | 06:26 PM
Navy_CRX's Avatar
Anyone know of a good diy diff rebuild writeup
Old Sep 23, 2010 | 06:49 PM
lazlong's Avatar
For salvage diff try craigslist. This guy is 2-3 hrs from you: http://cincinnati.craigslist.org/pts/1938754980.html
Or try http://www.car-part.com/index.htm
Old Sep 24, 2010 | 02:22 AM
wrXtian's Avatar
i'd suggest just going with 4.77
Old Sep 24, 2010 | 11:43 AM
Navy_CRX's Avatar
What all is needed to do a fd swap and where is the cheapest place to get it
Old Sep 24, 2010 | 03:55 PM
Navy_CRX's Avatar
Any link to a diff rebuild would be helpful
Old Sep 25, 2010 | 09:23 AM
Navy_CRX's Avatar
Well heres an update. I finnaly got a chance to jack up the car and found the rear drivers side cv boot is twisted. Its the side attached to the pumpkin. Would that be a cause for a bad grinding noise when i try to move the car. Reason i ask is i disconected the axle off the diff and tried to duplicate the noise and now the car dosent move but it also dosent grind any more.
Thanks for your help in advance
Eddie
Old Sep 25, 2010 | 12:17 PM
JUSTINTHECOASTI's Avatar
people on s2ki.com are sellin stock AP1 and AP2 diffs from 300 to 500 dollars right now, also try and find a stock header as well jkjkjkjkjkjk great buy!!!!
Old Sep 25, 2010 | 04:03 PM
Tuner Eddy's Avatar
Eddie
That might have been your problem, pick up a new axle and see if it fixes the problem.
Old Sep 26, 2010 | 08:14 PM
FirstGenCrx's Avatar
thats most likley the axle i had the same problem broke my driverside one but i ruined my diff as well had teeth missin on the ring and the pinion was kinda torn up but gl and conrats on the perchase
Old Sep 27, 2010 | 09:32 AM
White Smoke's Avatar
i my honda
Global Mod
So right now you just removed one shaft, tried to drive the car and it does not move? The reason for this is because the diff will apply force to the output with the least resistance. SAFELY jack up the rear of the car entirely (wheels off ground), have someone put it in first gear and release the clutch (while running). Now look under the rear end and see if the drive shaft is spinning, and then see if the output flange on the diff (that connects to the axle) is spinning. If both are and you do not hear a sound, all you need is an axle. (There could be other parts damaged in the hub assembly.)
Old Oct 1, 2010 | 11:37 AM
4doorH22's Avatar
Dude said he's a competent mechanic, surely he knows that plus the car didn't move before he removed the axle either.
Now that an axle is off an you can get an output shaft to turn without grinding, pinion and FD gear are probably okay but something in the inner diff assembly is blown. Getting a used differ is still probably going to be easier and cheaper than a rebuild.
wade
Welding / Fabrication
Mar 25, 2012 12:26 PM
Brandeezy1
Honda S2000
49
Apr 22, 2009 01:19 PM
streetraces
Feb 20, 2009 05:48 AM
square_1
Honda S2000
12
Nov 5, 2008 04:13 PM
shadhman
Honda S2000
Jun 30, 2008 09:30 AM
