95 accord speedometer not working, pic inside
Old Sep 23, 2010 | 04:49 AM
smokimon001's Avatar
Default 95 accord speedometer not working, pic inside
Hi every one,
I have 95 accord, Ex, auto, 2.2L single cam.
half yr ago, my speedo stayed/bounce at 20mph once the ignition is on, did the same thing even the car was moving. i replaced the VSS(bought from ebay), didn't solve the problem. after i scalped the epoxy on the speedo circuit board(see link http://www.flickr.com/photos/23732694@N03/4667583709/ ) speedo worked again. everything work the way they should.
This morning i was driving on highway, the speedo suddenly dropped to 0mph, D4 light started blinking, cruise control not working, engine check light came on after 10 mins, but the car drive just fine, when i came to a stop, i shifted to d3 or d2 or R, D4 light still blinks. then i shut off the car, start up again, D4 light was not blinking, engine check light went off. but speedo still stays at 0mph.
Would that be the VSS problem? bad ebay parts?
Should i check the code and clean the connections on VSS?
Suggestion please.
Old Sep 23, 2010 | 09:06 AM
DELuth's Avatar
Default Re: 95 accord speedometer not working, pic inside
Yup, aftermarket junk. I guess you didn't save the one you took off?
Old Sep 23, 2010 | 09:08 AM
DELuth's Avatar
oops, double
Old Sep 23, 2010 | 09:31 AM
i dont think i can find the old one anymore
Old Sep 24, 2010 | 12:51 PM
kornerk12's Avatar
bump
this same exact problem happened to me about an hour ago.
Old Sep 24, 2010 | 06:56 PM
bford's Avatar
when my vss failed on my car, my speedo would go on and off, intermittently. Sometimes it would just stay on while im driving, and then just start bouncing up and down.
try cleaning the connection first...that might help...but i dont think that will really solve the issue..
My suggestion to you would be to check your vss again...if possible get a hold of a genuine vss and not that of just from ebay..the one you got might be bad...
i solved mine with a vss from a friend..its used...but he knew it works...
hope this helps somewhat..
Old Sep 28, 2010 | 06:14 AM
most likely would be teh VSS, i am going to work with info from this link: http://techauto.awardspace.com/vss.html#Solutions
Old Oct 12, 2010 | 07:10 AM
turned out to be the VSS, i disassembled the VSS, cleaned the thick dirt off, put everything back in, seal with poly, my speedo works again
Cobalt_daddy
Oct 27, 2010 10:01 PM
Joserey90
Sep 17, 2010 06:12 PM
SpoonREVS
Feb 15, 2008 10:01 PM
zak88lx
Jun 5, 2007 01:33 PM
Frankie324
Jul 14, 2004 07:48 PM
