d16y7 block/y8 head mini me swap in my 97 hatch - bogging and misfiring
Old Sep 22, 2010 | 10:37 PM
89prelude069's Avatar
Default d16y7 block/y8 head mini me swap in my 97 hatch - bogging and misfiring
i have a mine me swap in my 97 hatch(d16y7 block with the y8 head). sometimes when i drive around 3500 to 4000 rpm it will start cutting out and bogging but if i put my foot in it then it stops, i reaplaced plugs, wires, and fuel filter but its still doing it. sometimes after it does this my cel comes on and its p0310 i think i know its for the first o2 sensor running slow or something like that. i can reset it and it doesnt come back on till it cuts out again(which is usually a couple days). any ideas on what could be causing this?
Old Sep 23, 2010 | 01:24 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: mini me not running right help!!!!
Are you sure its P0310, thats cylinder #10 misfire. If its a P0300-304:
# P0300 Random/Multiple Cylinder Misfire Detected
# P0301 Cylinder 1 Misfire Detected
# P0302 Cylinder 2 Misfire Detected
# P0303 Cylinder 3 Misfire Detected
# P0304 Cylinder 4 Misfire Detected
What ECU are you running? How did you wire up the 2 wire IACV? What injectors?
Old Sep 23, 2010 | 07:05 AM
Former User's Avatar
Check the cap and rotor.
Old Sep 23, 2010 | 07:23 AM
92lxsleeper's Avatar
like previous poster said. cap and rotor. you might have condensation building up and causing the spark to jump.
Old Sep 23, 2010 | 01:22 PM
Default Re: d16y7 block/y8 head mini me swap in my 97 hatch - bogging and misfiring
everything is stock y8 besides the block of course and when i ran the computer on it, the code that came up was for the o2 i know for sure it said bank 1 sensor 1 and something about it slowing. i will check my dizzy and see how it looks
Old Sep 23, 2010 | 01:27 PM
Also try unplugging the O2 sensor to see if it prevents the problem.
BIGef
Jul 1, 2014 10:53 AM
ArtyTheKid
May 26, 2013 03:02 PM
crzyfool24
Nov 22, 2004 04:23 PM
turbotime
Jul 1, 2003 06:08 PM
