b16 transmission - What clutch hardline is this?
I have a b16 transmission, with the bracket shown in the picture and my clutch line doesn't fit with that bracket. The clutch line I have is from the 99-00 si. I can't find another hardline that would fit with that bracket. All the integra / del sol VTEC clutch hardlines are different (wouldn't work with the rest of the line).
'99 - '00 Civic Si/JDM '96 - '00 Civic with B-series/Orthia. Actually the '96 - '00 D-series line is either the same or very close as well.
But that is 99-00 b16 tranny in the picture.......I am confuse
it sholud fit fine .....unless I am not understanding the OP question
that's my question. I have a b16 tranny, the 99-00 si clutch line, yet the bracket off the 99-00 si that the clutch line runs under (in the pic) doesn't fit?
Si parts don't fit the Si?
Any pics of your setup? It should fit. You can use the bracket that the clutch line bolts to off a Y7 as well. The Y8s i've seen all had a different bracket and i'm not sure if it will work, not sure if its a Y7/Y8 thing or a '96 - '98/99 - '00 thing.
Nevermind. I made a really silly mistake and ordered the EX clutch line when I originally replaced the clutch line. The part #s are very close with the only difference being A01 and A20 at the end.
redline870
Oct 10, 2012 06:19 PM
