b16 transmission - What clutch hardline is this?
I have a b16 transmission, with the bracket shown in the picture and my clutch line doesn't fit with that bracket. The clutch line I have is from the 99-00 si. I can't find another hardline that would fit with that bracket. All the integra / del sol VTEC clutch hardlines are different (wouldn't work with the rest of the line).
Seagull Management
Re: What clutch hardline is this?
'99 - '00 Civic Si/JDM '96 - '00 Civic with B-series/Orthia. Actually the '96 - '00 D-series line is either the same or very close as well.
Re: b16 transmission - What clutch hardline is this?
But that is 99-00 b16 tranny in the picture.......I am confuse
it sholud fit fine .....unless I am not understanding the OP question
Seagull Management
Any pics of your setup? It should fit. You can use the bracket that the clutch line bolts to off a Y7 as well. The Y8s i've seen all had a different bracket and i'm not sure if it will work, not sure if its a Y7/Y8 thing or a '96 - '98/99 - '00 thing.
redline870
10-10-2012 06:19 PM
