Del sol T bracket
Doing a B series swap into my Del Sol, found a bracket but its out of a automatic. I know the other B series brackets have to be drilled for the bolt to fit through to use for manual, is it the same with the auto b16a3 bracket?
Bracket has to come from a manual IIRC, should be different where it bolts to the transmission. Can come from any 5 speed '94 - '01 Integra or Del Sol Vtec
It's #12 in the pic.
Part number is 50827-SR3-N12 and sells for $53.21 from Majestic Honda <---click here for the actual link with the diagram, part numbers, and pricing. You can order direct from the link.
PhatHardy
11
Jun 23, 2005 01:05 AM
