civic 93 d15b coupe dx - stalls and difficult to restart
Old Sep 22, 2010 | 06:56 PM
chirby17's Avatar
Default civic 93 d15b coupe dx - stalls and difficult to restart
i need help on my fuel...when im at a dead stop on a light or stop sign and i let go of the clutch and gas at the same time(well not same time.) the car chokes?and trying so hard to go. when that happen i pulled over and i rev the engine and its sounds weird like deep sounds like really deep. when its on idle its fine but few sec later its starts getting loud..then i rev it again then it dies. and i start it up it cranks but wont turn over..i wait for few sec or mins its perfeclty fine when i start it up. then i rev its sounds fine then few mins later it comes back and starts to choke. i change the fuel filter back then cuz i thought it,but i guess im wrong? ppl help me out
when im on idle its fine. its not dying when im on idle. but some times wen im on idle engine sound loud like loud. only happens when it starts choking. hit me upp please
Old Sep 22, 2010 | 07:12 PM
munchies91crx's Avatar
Default Re: hep on civic 93 d15b coupe dx
this is very unclear in how its worded. but from what i got. your car chokes out at stop. and wont start sometimes when you try but if you wait after youve tried. it will start? and it idles up and down sometimes? okay
im going with this. idle could be do to iac, could be bad. not tight. car choking out could be maybe fuel pump giving out on you. or not enough power to it? thats why it doesnt start up sometimes...im not exactly sure. but from my expericence imma go with that. hope it helps. and hope some other more knowledgeable people could help more.
Old Sep 22, 2010 | 07:17 PM
chirby17's Avatar
thanks for answering..
yeah it chokes when i press the gas. when i turn it off and turn it back on then i rev it under the hood next to the manifold it still sounds like its still choking and deep rev. when i let it rest it seems fine after i let it rest. then it does it again and chokes .while idling its fine, not sputtering or anything.
Old Sep 22, 2010 | 07:19 PM
Former User's Avatar
As mentioned, cleaning the IACV sounds like a good idea.
Also check the spark plugs, wires, cap, and rotor. Any CEL codes?
Old Sep 22, 2010 | 07:21 PM
chirby17's Avatar
i change the spark plugs like 2 month ago but not the dizzy and wires nor cap. do you think it might be the dizzy? cuz back then the rpm use to bounce crazy..
Old Sep 22, 2010 | 07:23 PM
chirby17's Avatar
check engine light was always off cuz i think when i bought the car he plug it out or forgot to plug it
Old Sep 22, 2010 | 07:24 PM
Dontoh's Avatar
get that **** plugged in^
Old Sep 22, 2010 | 07:29 PM
chirby17's Avatar
ttt
Old Sep 22, 2010 | 07:35 PM
1) Check the wires, cap, and rotor. They may be old and worn, causing misfires.
2) Install a new CEL bulb in the cluster. The bulb either burned out or the previous owner removed the bulb. Once a working CEL bulb is installed, pull the CEL codes. See CEL sticky at the top.
Old Sep 22, 2010 | 07:40 PM
chirby17's Avatar
so these things ur telling me and caps and dizzy are bad it cud be causing the choking?
Old Sep 22, 2010 | 07:44 PM
Bad ignition components are the most common cause of engine misfire and bogging. Start by carefully inspecting/testing the ignition system components.
And get the CEL working ASAP.
Old Sep 22, 2010 | 07:48 PM
chirby17's Avatar
thanks ..ur not like all those ******** on here and other sites
Old Sep 22, 2010 | 07:54 PM
endlessone's Avatar
Default Re: civic 93 d15b coupe dx - stalls and difficult to restart
i have a similar problem.... if i stall(bad clutch or me haha) my car sometimes will not turn on. it cranks but does not start i usually have to wait like 2 minutes befor my car will start... anyone have advice
cjwang2
Jul 8, 2016 01:10 PM
IAluder95
Sep 1, 2007 09:52 AM
2kTeg
Mar 31, 2006 04:20 PM
vg7z
25
May 19, 2005 07:19 PM
