Clutch or Tranny Problems??
Old Sep 22, 2010 | 03:49 PM
LilTeggy2011's Avatar
Icon6 Clutch or Tranny Problems??
Car: 1994 Ls 5 Speed, 220k miles, headers, exhaust, intake....
Problem: For the past couple weeks my car has been acting up..At first my clutch pedal was feeling sticky and would grab quick and after awhile it went back to normal its hard to go into gears and sometimes they car wont go into gear, i have to shut it off and put it in gear then the clutch grabs. it sounds like there is metal on metal when in trying to go into 1st and a grind in 3 and 4... i would like to know if this is because of the clutch, and pressure plate or just the tranny....Help Me Please...
Old Sep 23, 2010 | 07:51 AM
Mindgamez's Avatar
Default Re: Clutch or Tranny Problems??
If you ever hear metal on metal stop driving the car. As for your problem your clutch is bad, Replace the Flywheel, Clutch, and Pressure plate.
Old Sep 23, 2010 | 09:21 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ although you may not need to replace the flywheel, unless you see signs of damage. 94
Old Sep 23, 2010 | 09:30 AM
evildc2's Avatar
release bearing its out
Old Sep 23, 2010 | 11:17 AM
so its the cluctch?? what bout the grinds?
Old Sep 23, 2010 | 02:04 PM
fcm's Avatar
fcm
Old Fart
If clutch does not disengage properly the gears, [synchromesh] will grind.
It is also possible the synchromesh has been damaged from trying to shift with a defective clutch. 94
lopezchris21
25
Nov 19, 2023 08:24 PM
JDM3STAGEVTEC
Dec 19, 2008 07:43 PM
Chiller
Nov 4, 2006 04:11 PM
vlc92189
Aug 30, 2006 11:10 AM
HS2G
Aug 22, 2004 07:34 AM
