D16y7 oil pump fit a d15b2?
Old Sep 22, 2010 | 03:17 PM
dc2nick's Avatar
Default D16y7 oil pump fit a d15b2?
Putting a d15b2 in my 97 civic just so i can drive it while I rebuild the d16 for more boost...
But the d15 doesn't have a crank position sensor. Will the d16 oil pump fit on it, so it will have the sensor and I wont have to just bypass the sensor?
Is there an obd2 oil pump I can use?
I see some people have run into the same problem in the past, but no one ever says what they ended up doing....
Old Sep 22, 2010 | 07:43 PM
dc2nick's Avatar
Default Re: D16y7 oil pump fit a d15b2?
No one knows huh?
Old Sep 22, 2010 | 08:34 PM
D16SiHatch's Avatar
i don't know if it will work but i can tell you the bypass is simple and seems to take care of the problem. it's a crankshaft fluctuation sensor (ckf) btw, not cps.
potatointegra01
Feb 2, 2016 04:23 PM
CRXherbie91
Mar 9, 2009 10:05 PM
warwagon
Jan 11, 2005 05:14 PM
