D16y7 oil pump fit a d15b2?
Putting a d15b2 in my 97 civic just so i can drive it while I rebuild the d16 for more boost...
But the d15 doesn't have a crank position sensor. Will the d16 oil pump fit on it, so it will have the sensor and I wont have to just bypass the sensor?
Is there an obd2 oil pump I can use?
I see some people have run into the same problem in the past, but no one ever says what they ended up doing....
Re: D16y7 oil pump fit a d15b2?
i don't know if it will work but i can tell you the bypass is simple and seems to take care of the problem. it's a crankshaft fluctuation sensor (ckf) btw, not cps.
