OBD conversion questions
Old Sep 22, 2010 | 01:40 PM
sir.rexington's Avatar
Default OBD conversion questions
If i have an OBD-0 to OBD-1 jumper harness for my crx is that all i need to run my OBD-1 ECU?? i have an OBD-0 engine harness.... i have read that some people re wire, re pin or re do something to convert it. did i get the jumper harness to keep from having to re wire anything? can i keep the OBD-0 distributor? also my car was a DPI but i have an OBD-0 harness with four injector plugs do i need to add anything? people where i live claim to know whats going on but i am hearing different opinions from different people.
Old Sep 22, 2010 | 01:51 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: OBD conversion questions
First thing is to take care of the DPFI>MPFI conversion because there is no OBD1 or newer ECU that uses two fuel injectors as far as I know. Having said that, it is easier to convert your DPFI harness into a MPFI harness vs trying to install the MPFI harness you have. After that is taken care of, you'll need an OBD1 distributor to match your ECU (your conversion harness may or may not include the pig tails for the newer distributor).
Old Sep 22, 2010 | 03:32 PM
crx_si-r's Avatar
You need the following:
Obd1 distributor to match your motor
4 wire o2 sensor
Repin your wiring for the new distributor
Old Sep 24, 2010 | 06:31 PM
Mugencrxsir1's Avatar
Those of you with a Universal 4 wire O2 sensor how did you figure out which of the 4 wires from the O2 sensor go to the correct/corresponding wires on the jumper harness? No diagram on the O2 sensor from Bosch...
Thanks,
Old Sep 24, 2010 | 08:21 PM
JeffBro's Avatar
You don't need an OBD1 distributor. If you have an OBD0 or OBD2 dizzy you can just use a conversion harness or wire it up yourself. I did that on my OBD2 GSR swap in my CRX. For the O2 sensor do you have the stock plug already on it?
Old Sep 24, 2010 | 09:19 PM
Bump for O2 answer...
Old Sep 25, 2010 | 10:40 AM
i have a one wire O2 sensor right now.
Old Sep 25, 2010 | 10:41 AM
4 wire o2 sensor
done that...except i haven't acquired the 4 wire sensor.
Old Sep 25, 2010 | 01:37 PM
hatchet_honda's Avatar
obd1 ecu=4 wire 02
Old Sep 25, 2010 | 08:19 PM
JeffBro's Avatar
I was thinking he had some weird aftermarket 4 wire 02 sensor. That clears it up. everything will make sense when you get the 4 wire sensor
Old Sep 26, 2010 | 05:56 AM
HERE i come craigslist.
Old Oct 6, 2010 | 06:37 AM
everything is good on the distributor, i'm now researching the obd1 injector wiring.
Old Oct 20, 2010 | 07:04 AM
when i turn the key i hear a loud click, and the BRAKE light comes on in the dash. and of course it's not cranking.....?
Old Oct 20, 2010 | 07:17 AM
crx_si-r's Avatar
are you running obd1, obd2 or obd0 injectors?
Old Oct 20, 2010 | 07:21 AM
slywfbpsi's Avatar
Originally Posted by hatchet_honda
obd1 ecu=4 wire 02
D15B vtec and zc vtec = P08 ecu = ODB1, only uses 1-wire o2
Old Oct 20, 2010 | 01:48 PM
LS non VTEC B18A1 obd 1 injectors p 72 ecu ITBs
bobbyisking
Jul 7, 2008 09:22 AM
koleslaw
Mar 24, 2007 09:39 PM
lsvtec_hatchback
Aug 31, 2006 09:25 AM
88da3
Nov 13, 2003 01:12 PM
Norcalstoppy
Sep 20, 2003 05:45 PM
