jdm h23a vtec on 98 accord
Old Sep 22, 2010 | 07:28 AM
ekcoupev's Avatar
Default jdm h23a vtec on 98 accord
was up i just swap a jdm h23a vtec motor to my accord and i use the harness of my stock f23a1 motor to wire up the motor..now the problem is that the car turns on wit the stock f23a1 ecu and it dont want to turn on wit a chipped p28 and obd2b-obd1 step down harness..idk why is thati need help wit this anyone
Old Sep 22, 2010 | 07:36 AM
ekcoupev's Avatar
Default Re: jdm h23a vtec on 98 accord
tttttttttttttttttttttttt
Old Sep 22, 2010 | 08:01 AM
ekcoupev's Avatar
ttttttttttttttttttttttttttttt
Old Sep 22, 2010 | 09:18 AM
nus_dogg's Avatar
You'll need a OBD1 ECU and run the CKP sensor wire to the OBD1 distributor because the OBD1 distributor has the CKP inside the dizzy.
I heard, you'll need a OBD1 H22A Intake Manifold and Injectors as well. Not sure, double check.
Old Sep 22, 2010 | 09:22 AM
ekcoupev's Avatar
all h series got the ckp inside the dizzy..i already ran the cables the car turns on but wit the stock ecu not wit the chipped p28 and i got the step down obd2b-obd1
Old Sep 22, 2010 | 03:36 PM
nicolas1320's Avatar
dude there has to be something rong with the stepdown harness because I have the same engine in a 96 accord wagon with a p28 with prelude basemaps and I din't get no problems.make sure that all wires match on the stepdown harness
Old Sep 22, 2010 | 04:10 PM
nus_dogg's Avatar
Not the OBD2 H22s. I was told they are on the oil pump housing unlike the OBD1.
More info about OBD2 H22 CKP: http://www.preludeonline.com/f60/h22...-sensor-238680
Old Sep 22, 2010 | 04:22 PM
ekcoupev's Avatar
wat stepdown are u using right now man?
Slowcg5
May 25, 2018 12:14 PM
Corey Millsap
Dec 24, 2015 11:47 AM
SingleCamin
14
Mar 7, 2009 10:14 AM
puertoroc7976
Oct 10, 2006 05:19 PM
