b20 vtec sleeves?
Old Sep 22, 2010 | 06:52 AM
ekcoupeh22's Avatar
Default b20 vtec sleeves?
whats going on guys im starting a build and im going to do a high compression b20vtec 13.0+ in compression some ppl have told me about the sleeves being weak i just want to hear from ppl that have b20 vtec's with high compression and heard the good and bad thanks guys!
Old Sep 22, 2010 | 06:57 AM
horn12007's Avatar
Default Re: b20 vtec sleeves?
well I had a boosted b20 vtec and it cracked all the sleeves. I have pics if you want to see. It could have been a bad tune that helped, but I don't think I would do anything radical to a b20 unless you throw some darton or golden eagle sleeves in there. Some all motor guys will be able to tell you for sure
Old Sep 22, 2010 | 06:58 AM
rick_rabies's Avatar
I'm not Rick!
lol.
13. comp would be the limit where you would prolly need sleeving. but
depends what your doing with it. alot of people go without sleeves and get away with it. its up to you. usualy the rule of thumb is "u gotta dish out $ for some powa"
Old Sep 22, 2010 | 01:34 PM
00Red_SiR's Avatar
All Motor Mentor
Doing it reliably all the time on stock sleeves is quite common, you just have to know what you're doing:
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%2A%2A%2Aofficial-all-motor-stock-sleeve-b20vtec-thread%2A%2A%2A-1555476/
Old Sep 22, 2010 | 01:52 PM
DDTECH's Avatar
Originally Posted by rick_rabies
lol.
Not true.
Stock sleeves aren't weak - They are **** to low rpm/ high load knock thats why they get split or crack cause idiots flooring it at 2k rpms in like 3rd gear, and the ign isn't tuned correctly.
I'm running 13.0CR daily driven, stock b20 sleeves. with a block guard. Your fine.. plenty of b20vtec's making well over 375whp on stock sleeves.
Old Sep 22, 2010 | 03:41 PM
092eg6's Avatar
b20 sleeves are fine
Old Sep 23, 2010 | 03:24 AM
ekcoupeh22's Avatar
alright thanks guys that was very helpfull!!! now i can go build my motor and not have sweat drip down my forehead when i go to drive it!
Old Sep 23, 2010 | 10:03 AM
neverstop's Avatar
with a VERY good tune you should be fine. just have the motor built and tuned by someone who really knows there stuff and you'll be ok. there are many b20vtecs that have taken 100+ hp shots of nitrous and I've seen more than a few 400whp boosted b20s too, the thing is they were put together and run by people who are VERY good at this honda game. you put an FMU on there and floor it up the street without a tune and I bet it lasts 5 minutes.
775JDMEG
11
Oct 19, 2010 08:59 AM
JDM97EK
Oct 28, 2006 09:12 PM
KilaB18C
Oct 15, 2004 09:08 AM
jerseyboy22
Jan 9, 2004 04:32 AM
project_DC2
Mar 1, 2002 08:53 AM
