help with cel 6 on cb9
Old Sep 21, 2010 | 05:06 PM
dragon_lowrider's Avatar
Icon6 help with cel 6 on cb9
hello everyone, i have a 92 cb9, yes its a wagon big whoop want to fight about it?, lol, anyways, i pulled two codes, cel 6 and the iacv code, replaced all the vacumm lines, cleaned the iacv, and fast idle thermo valve, replaced and the coolant lines, along with all 4 temp sensors switches, now it still idles like a bad iacv, but that code is gone, no still have the cel 6 code, car drives and runs great, trying to fix this prob for the idle problem and to get it smogged, anything would help thanks guys
Old Sep 21, 2010 | 05:52 PM
phootbag's Avatar
Default Re: help with cel 6 on cb9
Confirm the base idle with the PGM tester.
redbull-1's Avatar
Code 6 is the ECT sensor.
Old Sep 21, 2010 | 06:16 PM
base idle is 700 rpm
the ect sensor was replaced, all four sensors were replaced
Old Sep 21, 2010 | 07:12 PM
phootbag's Avatar
Idle with the IAC unplugged should be around 450, barely running. However, you should do this with the PGM tester so the ECM doesn't start running in default because of the unplugged IAC.
Old Sep 22, 2010 | 07:36 AM
92civlude's Avatar
Check the voltage at the ECT (TW) sensor. Key on engine off you should have 4.5 to 5v at the yellow/green wire. And a ground signal at the green/white wire. Ive see loose terminals at the left shock tower connector cause problems like this.
Old Sep 22, 2010 | 10:55 PM
Well I fixed the cel, it was a bad connector, went to pick a part and fixed that, and also got a new iacv, also found a prob with the coolant line and fixed that all lights are out and the car is running great, started it up no idle probs or anything drive it for about 15-20 mins parked it and it started the damn idle prob again, I'm confused all vacumm lines are brand new silicon hose, I bled the coolant system the way it is soposed to of been bled, so where do I go from here? I mean no codes but idle probs, anyone?
nicwin
Aug 23, 2018 09:21 AM
danielolaguez92
Sep 8, 2013 07:23 PM
reed857
29
Jul 26, 2009 10:57 AM
punkracer
Feb 1, 2009 06:57 PM
4potnick
Jul 21, 2002 10:49 PM
