my 95 ej1 making ticking noises
Old Sep 21, 2010 | 02:12 PM
weaseloko's Avatar
Default my 95 ej1 making ticking noises
I dont know if its a bad piston ring , but when i pull the spark plug wire off the engine sounds like its getting better but then sounds crappier, then when i put it back in it sounds way better than just gets normal again, but it still makes this ticking sound. please help
Old Sep 21, 2010 | 02:15 PM
Former User's Avatar
Default Re: my 95 ej1 making ticking noises
Removing a plug wire while the engine is running is among the most effective ways to blow the coil.
Are you sure the engine is just not missing due to an ignition system problem (plug, wires, cap, and rotor)?
Have you compression tested the cylinders?
Old Sep 21, 2010 | 02:18 PM
weaseloko's Avatar
well i did see oil in the plug when i removed the plug wire but im not sure if its the dizzy or rotor sorry if i sounded like a new-b
LawlessOne
Mar 13, 2012 12:35 AM
lethalgsr32
Dec 31, 2005 01:37 PM
Jasz
Jun 26, 2005 08:13 AM
Yokohama
12
Jul 2, 2003 12:59 AM
2camsaam
Oct 3, 2002 11:00 PM
