Suspension & Brakes Theory, alignment, spring rates....
Slammed car axle problems
Old Sep 21, 2010 | 10:32 AM
blake22's Avatar
Default Slammed car axle problems
I got a slammed accord and keep having axle problems. Any suggestions would be great
Old Sep 21, 2010 | 11:07 AM
emooheo's Avatar
Default Re: Slammed car axle problems
unslam ur car
Old Sep 21, 2010 | 11:37 AM
NinJa_FLiP's Avatar
my initial thought would be to raise it.. but what kind of axle problems you having?
Old Sep 21, 2010 | 11:43 AM
blake22's Avatar
I think I might have to raise it. My axles are no where close to level and even new axles click around turns.
Old Sep 23, 2010 | 04:47 PM
NinJa_FLiP's Avatar
the clicking usually means the bearings are bad.. did u check to see if the cv boots were ripped?? also, it doesnt necessarily have to be exactly level.. just get a set of replacement axles from the parts store with a warranty.. swap em out.. and if the new ones break and start clicking on turns again, then yes u do have to raise it up a bit.. good luck
Old Sep 23, 2010 | 08:06 PM
blake22's Avatar
the boots are fine one axle is brand new and the other one has like 100 miles on it. i think my only option is to raise it up. bummer
Old Sep 24, 2010 | 09:55 AM
gabebauman's Avatar
Is it a click or a knock sound? I had an issue with my replacement Autozone axles being too long and they binded so they made a knocking noise when I turned. Got some from Napa that were the right length and it cured the problem.
Old Sep 24, 2010 | 12:54 PM
blake22's Avatar
its a definite click. i think i might just have to get another axle and raise it a little.
Old Sep 24, 2010 | 05:11 PM
JDM_CG7's Avatar
make sure you strut are not close to your axle in the forks make sure there even with the bottom of your strut with your fork
Old Sep 24, 2010 | 05:13 PM
JDM_CG7's Avatar
gabebauman its best to stay with stock the axles from kregen,autozone an napa are all china made and will some time give up an snap and they also dont have no balancer either
Old Sep 24, 2010 | 06:36 PM
gabebauman's Avatar
My NAPA axles are lifetime warranty. I'd be amazed if my 126hp B20 was able to snap an axle. Besides...I'm not mad-tight slammed on blown shocks like you.
Old Sep 24, 2010 | 07:17 PM
Drive 4 fun's Avatar
I would talk to Raxles, very knowledgeable and might be able to help. Choice could be Raxles or raise.
Old Sep 24, 2010 | 07:48 PM
dapek's Avatar
^Why? Gabe already answered the question.
It's simple, raise your car to a functional height, and replace the axle/s. The clicking noise is your axle. Being "slammed" completely messes with all of your suspension components in different ways, none being positive. GL
Old Sep 24, 2010 | 08:10 PM
No argument with raising. Just thought that the OP did not seem to want to go that route. I thought that they might be able to give him a height or parameter that their axles could function, "functional height." They use quality material, boots and new joints, and have been willing to discuss use in our cars. I found them helpful.
Old Sep 24, 2010 | 08:35 PM
dapek's Avatar
That's true. He might as well just swap out the axles, and raise it a bit. Also, sub par suspension (ie. ebay coilover sleeves, etc.) can cause your axles to go regardless of being slammed or not do to the ridiculous amount of bounce.
OP, what's your suspension setup and are your axles aftermarket? I may have missed it.
Carasith
Nov 15, 2018 06:03 PM
ZXiPoZ
May 30, 2012 10:15 AM
8_UR_AWD
Transmission & Drivetrain
Feb 2, 2009 09:57 PM
mingbling96
Mar 13, 2005 08:14 AM
b20guy
Jul 4, 2003 01:43 PM
