WTF, i don't understand this......
Old Sep 18, 2002 | 08:49 PM
Boostless97Lude
Guest
Posts: n/a
Default WTF, i don't understand this......
ok, i took my engine apart, sent it to be re sleeved, and i finally got it back, well, i go to check the letter stamped on the block so that i can cross-reference the crank to see what color bearing i need, and, wel, it was a number, not a letter. the number 4 was stamped there. at first glance i thought, oh, it's an "A", but i looked again, yes, it's a number 4. i am confused as hell, i can't figure this one out for the life of me. has anyone else had this problem???
also, i had never actually checked, i always thought that the USDM base Prelude was a BB8 (don't remember where i got that info, it was even used as a reference with my GReddy turbo kit), well, i had never really payed that close attention to my VIN number, but while i was cleaning the block, i noticed that the VIN number said BB6, not BB8. ok, does anyone have a clue which is which for sure???
Old Sep 19, 2002 | 06:58 AM
EKhatch's Avatar
Default Re: WTF, i don't understand this...... (Boosted97Lude)
A buddy of mine has a factory service manual for his lude. I will try and look in it to get the answer for you. What engine do you have?
Old Sep 19, 2002 | 08:10 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: WTF, i don't understand this...... (EKhatch)
i've got the factory manual, it doesn't help, is says i need the letter off the block, not a number
Old Sep 19, 2002 | 11:22 AM
Mikey3000's Avatar
where did you look for the letter? on the bottom of the block where the oil pan bolts up? there should be 5 letters there. each one of those letters corresponds with a number stamped on the crankshaft, and that tells you which bearing you need for that journal.
Old Sep 19, 2002 | 12:24 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: WTF, i don't understand this...... (Salvatore Leone)
NO LETTERS!!!!!!!!! it was just numbers..... 5 stamps, number 4 on each
Old Sep 19, 2002 | 12:26 PM
Mikey3000's Avatar
maybe they're all numbers on obd2, or 96-up cars.
Old Sep 19, 2002 | 02:01 PM
Boostless97Lude
Guest
Posts: n/a
the B18C5 i tore down last week had letters..... the book even says it should have letters, but mine has numbers
Old Sep 19, 2002 | 02:24 PM
Mikey3000's Avatar
very weird.
Old Sep 19, 2002 | 04:48 PM
Boostless97Lude
Guest
Posts: n/a
your tellin me
fungus mungus
Apr 22, 2011 09:22 PM
CARMA_626
Dec 12, 2010 04:33 PM
DC2 to AP2
Oct 3, 2005 06:38 AM
sporkcrx
Feb 7, 2004 08:21 PM
Boostless97Lude
Sep 19, 2002 07:14 AM
