Suspension & Brakes Theory, alignment, spring rates....
How to fix busted Integra front sway bar link kit ??
Old Sep 20, 2010 | 09:03 PM
GWInquisitor14's Avatar
Default How to fix busted Integra front sway bar link kit ??
I broke the front driver's side sway bar link on my 94 integra and I am having a hard time fitting the new replacement link I bought in between the control arm and the bar. The bushings on the new link are too fat to fit in the gap, much less the spacer that comes with it.
Does anyone have a good write up or instructions on how to make this work? Do I need to undo the other side in order to get more play to stack the new bushings?
Old Sep 21, 2010 | 06:38 AM
phunhaus's Avatar
Default Re: How to fix busted Integra front sway bar link kit ??
Have you tried to loosen the other side or use a jack on the wheel while the car is in the air?
Old Sep 21, 2010 | 05:44 PM
I haven't tried to loosen the other side but if I do, I'll have to replace it because its so rusted...I'll do it if its the only way to do it. I don't see how a jack on the wheel will pull the control arm down
Old Sep 21, 2010 | 07:18 PM
kyden's Avatar
you'll have to jack up the other wheel, since its pulling down on the sway bar.
Old Sep 28, 2010 | 04:17 PM
yup that worked, thanks
cheggie
Aug 14, 2016 03:59 PM
crispyflame
Suspension & Brakes
Apr 6, 2014 08:27 AM
langjairicer
Suspension & Brakes
Dec 20, 2009 09:47 PM
anonymus913
Oct 21, 2009 01:15 PM
