EJ8 delay in ON(II) for cluster lights to turn on and starts then dies
Old Sep 20, 2010 | 09:02 PM
EK_B's Avatar
Default EJ8 delay in ON(II) for cluster lights to turn on and starts then dies
So recently when I put my key into the ignition and turn it twice (ACC) it takes awhile for the lights in the cluster to light up.
Than sometimes when I crank the car, the car starts for a second and dies. Then I try again and than it works.
Can someone help me diagnose this please? This started recently like 2 days ago, I've never had this problem before.
Old Sep 20, 2010 | 09:07 PM
USDM sI's Avatar
Default Re: What's wrong with my EJ8??
try replacing the fuel filter happened to me in my eg and my ef
but in the ef it was the fuel pump that was going out also
Old Sep 21, 2010 | 05:10 AM
Former User's Avatar
Default Re: EJ8 delay in ON(II) for cluster lights to turn on and starts then dies
An informative thread title is required and helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Check the ignition switch:
Old Sep 21, 2010 | 06:26 AM
EE_Chris's Avatar
There was a TSB for the ignition switch in some 6th gen Civic's that detailed this sort of behavior (car started, let go of key and it'd die).
Old Sep 21, 2010 | 06:50 AM
EK_B's Avatar
So does it matter if it gets fixed? I guess will anything worse happens if I continue to drive like this?
I'm just wondering if it's one of those things that is just a convenience problem like a burnt out gauge cluster bulb and not a big problem like a brake or engine malfunction.
Old Sep 21, 2010 | 08:07 AM
Check the ignition switch with a multimeter. A bad switch will get worse to the point that you will not be able to start the car.
jonathanwef1991
Apr 25, 2017 07:56 PM
4dr2k1civic
Mar 1, 2013 05:26 AM
ACC2003
May 8, 2012 08:15 PM
wes7side5o
Mar 22, 2007 05:07 PM
