Fenderwell Trim on ITR
Old Sep 18, 2002 | 08:36 PM
vtec.dc2's Avatar
Default Fenderwell Trim on ITR
this would apply to other integras as well..
i was told before to remove fenderwell trim - since it causes rust after some time (few years maybe?).. any of you removed it? i started to remove it, then thought about rocks hitting the paint.. and eventually leading to rust...
latest generation hondas don't seem to have it.. 3rd generation integras came out in 94, so I'm thinking at some time honda realized fenderwell trim isn't soo good in the long run?
Old Sep 18, 2002 | 08:51 PM
REVolution's Avatar
Default Re: Fenderwell Trim on ITR (vtec.dc2)
I pulled mine off shortly after purchasing the car. They are traps for moisture and with time can lead to rust. I just looked at my fenders and not a scratch or paint chip to be found...that's two years of daily driving. So, don't worry about the scratches.
Old Sep 18, 2002 | 08:59 PM
vtec.dc2's Avatar
Default Re: Fenderwell Trim on ITR (REVolution)
thanks for reply.. forgot to mention - my wheels/tires stick out further.. anyone with wider wheels/tires and fenderwell trim removed.. and no problems?
Old Sep 18, 2002 | 09:03 PM
Reid's Avatar
Global Moderator
What exactly is this fenderwell trim of which you speak?
Do you have a pic?
Old Sep 18, 2002 | 09:08 PM
Type Goch's Avatar
New User
Default Re: Fenderwell Trim on ITR (Reid)
I believe he's referring to the rubber trim that goes along the Fenderwell edge..
Old Sep 18, 2002 | 09:10 PM
kkim's Avatar
reid,
must be the rear wheel well plastic trim on the top of the wheel arch.
Old Sep 18, 2002 | 09:12 PM
vtec.dc2's Avatar
its a plastic trip that goes around the enge rear fender, it covers it up to the bumper
[Modified by vtec.dc2, 1:20 AM 9/19/2002]
Old Sep 18, 2002 | 09:14 PM
Reid's Avatar
Global Moderator
There is no downside to removing it.
Old Sep 18, 2002 | 09:17 PM
AllMotorITR's Avatar
New User
Some people remove it to avoid rubbing with larger wheels.
Old Sep 18, 2002 | 09:18 PM
vtec.dc2's Avatar
Old Sep 18, 2002 | 09:20 PM
TypeR 599's Avatar
bling BlinG...
Old Sep 18, 2002 | 09:25 PM
kkim's Avatar
OT-what kind of wheels is that?
Old Sep 18, 2002 | 09:30 PM
vtec.dc2's Avatar
Default Re: Fenderwell Trim on ITR (kkim)
https://honda-tech.com/zerothread?id=275481..
[Modified by vtec.dc2, 1:52 AM 9/19/2002]
Old Sep 19, 2002 | 12:52 AM
Tommy_Gunns's Avatar
I think it is best to leave it on and spray some rust inhibitors in it.
I recently had some rust removed from my rear fenders. The rust was located where the fender trim was not present.
Old Sep 19, 2002 | 04:56 AM
BlackAckeR's Avatar
Default Re: Fenderwell Trim on ITR (Tommy_Gunns)
Looks pretty crappy without it, especially on white/yellow R's....
Old Sep 19, 2002 | 06:31 AM
01-1293's Avatar
Default Re: Fenderwell Trim on ITR (BlackAckeR)
i took mine off right away.............a guy I know has worked as a professional detailer for like 4 years..........he told me how he always had integras come in with rusted out rear fenders.....its too late when you finally notice it
Old Sep 19, 2002 | 07:22 AM
vtec.dc2's Avatar
anyone else had problems.. need more opinions
Old Sep 19, 2002 | 08:58 AM
Reid's Avatar
Global Moderator
Why don't you try asking in the regular Integra forum?
Most people with Integras read that forum, not this one.
Old Sep 19, 2002 | 09:36 AM
skafia's Avatar
25 Year Member
I had a 94 Integra for 2 years and up until then it never rusted like you guys speak of. Maybe it's the weather conditions, i'm in hot *** so cal. I would personally leave it.
Old Sep 19, 2002 | 09:45 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Fenderwell Trim on ITR (skafia.cw.r)
Why are people in So cal even repsonding to this thread?
Anyhow, yes, they trap salt/mud/dirt in there that can lead to rusting. If you are worried about the chips, buy some of that underbody spray and hit the outside of the lip with it (masking off the body of course). And when you wash, run a hose up under there to flush everything out.
I just took my trim off of my ITR and there was all kinds of crap up in there. Even salt from where I had to drive the car one winter back two years ago. And I am very conscience when it comes to washing under there.
Old Sep 19, 2002 | 05:08 PM
vtec.dc2's Avatar
Default Re: Fenderwell Trim on ITR (Todd00)
thanks for all replies.. i removed the trims.. if it starts to rust anyway at some point, at least i can see it before it gets worse..
Old Sep 19, 2002 | 05:18 PM
Dropspeed's Avatar
Removed mine.
Old Jan 29, 2003 | 05:58 AM
IdotheSHOCKER's Avatar
Default Re: Fenderwell Trim on ITR (Dropspeed)
Just bought a 97 and since this topic is on the trim, is there a lot of glue residue under the trim that holds it?? if so whats the best way to get that off??
Thanks.
Old Jan 29, 2003 | 08:02 AM
Mugen Mike's Avatar
I had problems with it in my old hatchback. I would advise taking it out
Old Jan 29, 2003 | 08:07 AM
vtec.dc2's Avatar
Default Re: Fenderwell Trim on ITR (MugenMike)
thanks, took them out back in september
anyone else had problems.. need more opinionsI had problems with it in my old hatchback. I would advise taking it out
from 9:08 PM 9/19/2002
[Modified by vtec.dc2, 12:09 PM 1/29/2003]
