Using a New Cluster
Old Sep 20, 2010 | 03:43 PM
Wiretaju's Avatar
Default Using a New Cluster
awrite so i just recently converted my ef hatch to 5spd and i was just wondering if i could just get the manual cluster and use it without changing the ecu or anything, just the cluster. will it work great?? if not what rpm guage should i get as in brand and stuff. please help thanks
Old Sep 20, 2010 | 04:34 PM
hasty91ef's Avatar
Default Re: Using a New Cluster
did you change the ecu from a auto to man. the cluster doesnt effect that just goes in no problem
Old Sep 20, 2010 | 11:32 PM
Wiretaju's Avatar
Nope, did not change the ecu. So u mean I can use a manual cluster and it'll work perfect with the auto ecu??
Old Sep 20, 2010 | 11:42 PM
dacrxguy's Avatar
yes it will but remember to get the same style of cluster (88-89)(90-91) since the wiring is different
Old Sep 21, 2010 | 12:47 AM
Wiretaju's Avatar
awrite thanks guys, you guys helped a lot
Old Sep 21, 2010 | 12:48 AM
Wiretaju's Avatar
oh yeah wait one more thing, will the rpm guage work with the auto ecu??
Old Sep 21, 2010 | 12:55 AM
Nooch's Avatar
Well first you need manual ecu. Clusters don't matter, throw whatever you want in just make sure you know what your wiring.
Old Sep 21, 2010 | 12:58 AM
Wiretaju's Avatar
so in order for the rpm to work i need the ecu?? if so which ecu do i need?? dx model
Old Sep 21, 2010 | 01:05 AM
Nooch's Avatar
No, in order for your car to work it'll need manual ecu, haha.
The tachometer doesn't require a specific ecu at all, as far as I know of but I'm 99% certain of that.
Old Sep 21, 2010 | 01:12 AM
Wiretaju's Avatar
so the tachmeter would work on an auto ecu?? lol
Old Sep 21, 2010 | 06:57 AM
dacrxguy's Avatar
Yes the tach will work and like a said you need your year specific ecu. As for needing another ecu you dont "need" it i ran the auto ecu on my car for months the only thing that will happen is that the check engine light will be on because of code 19 converter lock up solenoid.
Old Sep 21, 2010 | 04:31 PM
Wiretaju's Avatar
awrite thanks, saved me alot of stress haha
Old Sep 21, 2010 | 04:38 PM
hatchet_honda's Avatar
if you swap in another cluster just make sure its right for your year. wiring is diff. tach will work with auto ecu but as stated you will have a cel on.
Bobbie Owensby
Jun 16, 2016 02:13 PM
Reliv12
Oct 28, 2013 01:17 PM
Voodoo7
11
Mar 25, 2012 05:58 PM
pK1spooled
Oct 2, 2004 01:24 PM
endlessdv
Apr 13, 2004 02:46 AM
