can i block this IAC water pipe?B18C4 Turbo cooling system -
Old Sep 20, 2010 | 01:48 PM
jamesfawcett's Avatar
Default can i block this IAC water pipe?B18C4 Turbo cooling system -
Hey everyone!
i have fitted a skunk2 manifold to my b18 engine and a turbo, but there was one pipe left over from the top of the radiator outlet pipe.
its on the top of the outlet, and i think might supply the IAC valve and the throttle body with water, but ive snapped the pipe
it didnt go to anywhere after fitting the skunk2 manifold, so can i just tap it and screw in a bolt?
is this water feed pipe needed for the IAC valve?
ive highlighted it in red here:
thank you
james
Old Sep 20, 2010 | 03:58 PM
b18cek4's Avatar
Default Re: can i block this IAC water pipe?B18C4 Turbo cooling system -
Are you planning on using the stock throttle body?
Old Sep 20, 2010 | 04:33 PM
Turbogixxer's Avatar
yes, you can. It is used to heat the TB and IACV in the cold winter. It is not really needed for race cars.
Old Sep 21, 2010 | 12:22 AM
Icon2 Re: can i block this IAC water pipe?B18C4 Turbo cooling system -
Thank you I will block it off, I am getting an iac error code in hondata and it won't idle, and I read on here about people having idle problems with no or low coolant in the system. I've cleaned out the iac followig the hondatech guide but it didn't work, it ran perfect In the Honda.
Old Sep 21, 2010 | 12:25 AM
Hi yes standard throttle body for now, it going to be my daily driver and it gets c
very cold here in winter
Old Sep 21, 2010 | 10:17 AM
dpetro1's Avatar
low coolant or air in the system may cause idle problems but will not cause code 14 (IACV). you should look into the wiring or the iacv itself
Old Sep 21, 2010 | 02:27 PM
hi dpetro1!
thankyou, ok that is great news, ok i will block this pipe up,
and i will check the voltages at the IACV, and probably replce it
than kyou
james
Old Sep 21, 2010 | 03:58 PM
crxcel's Avatar
is that in an austin mini?
Old Sep 21, 2010 | 11:39 PM
Hey yes it is a 1968, this is the third time I've full rebuilt it, this is he biggest engine so far
Old Sep 22, 2010 | 12:52 AM
david974's Avatar
check if you didn't invert Iac plug with Iat plug or evap canister Plug
they are both close to each other
Dead CIVIC
Sep 11, 2009 07:21 AM
EG Boostin
Feb 1, 2007 12:46 PM
lsvtechatch92
Dec 16, 2006 09:49 AM
alpha_1
Apr 3, 2006 02:44 AM
