B16 head on b20 block
I wanna get a b16 head. Wat else would i need for the b16 head when i get it. Rite now i have an ls head on the b20 block but idk wat i need other than the head idk wat else i need.
O n my speedo isnt workin, any ideas wat i should do to get it working
Research!!!!
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
and the speedo could be the sensor no good or not plugged up or the cluster is no good
Not to be a dick, but does the sticky not inform any noobs anymore and the search bar just suddenly disappeared?
And lastly, don't half *** that B20V if you decide to go for it, build the bottom end to handle power at high rpm or else you are looking at a hole in your block.
ALLmotor_89
26
Mar 26, 2010 01:27 AM
herk_1
Oct 29, 2008 10:35 AM
