eg auto to man problem - shifter leans to right and won't go into reverse
Old Sep 20, 2010 | 10:44 AM
-=ZAK=-'s Avatar
Default eg auto to man problem - shifter leans to right and won't go into reverse
okay i fully converted a auto hatch to a manuel cranks runs whole 9 yards but, went to install my shiftlinkage, punched out the whole and bolted it up looks fine but leans very far to the right and wont go into reverse, lost the bitch pin and used a 12mm bolt. seems like the weights on the back are hitting my bushing to. if anyone knows a way to fix this please txt me att 256-5six six 8760 my name is zak.
Old Sep 20, 2010 | 11:07 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: eg auto to man problem - shifter leans to right and won't go into reverse
are you sure you have shift linkage for that motor? d series or bseries?
are they binded ie, crisscrossed
Old Sep 20, 2010 | 04:02 PM
hatchaddict01's Avatar
it deffinatly sounds like you have the wrong shift linkage. what year is the car and whats the set up
Old Sep 20, 2010 | 04:24 PM
92lxsleeper's Avatar
its because you dont have the bitch pin installed. the 12mm bolt you have allows for too much play. trust me i tried it the first time i did my swap a year ago, cause the bitch pin was a pain in the ***.
go to honda. its $2.00 and put it in.
Old Sep 21, 2010 | 05:06 AM
I'm not Rick!
ive ditched the pin in several cars when swapd and just used a bolt. worked fine
ChevelleSSLS6
Apr 7, 2009 09:16 AM
jdm_vtec
Jul 28, 2007 12:15 PM
menkio
Oct 22, 2004 06:44 AM
egg_baLLa
24
Aug 19, 2004 08:59 PM
Egone
Mar 9, 2004 08:42 PM
