Bilding Motor
I got a 95 ex motor from this guy for $100 and the only thing is its in pieces. Its got new piston rings and its honed but Do certain pistons go in certain cylinders?? I dont wanna mess this up cuz my car has been down for 3 weeks and i dont wanna have to do another swap, that will be th 3rd since this past summer. Also does anyone know how much new bearings cost? for the rods and the crank
You need to get a service manual. It will tell you everything about how to find what color bearings for each rod and all manis. Anyway to get you started. On the sides of the rods thers a #. On the block there are letters. On the crank there are #s and letters you have to match them up to find out what bearing you need. It doesn't matter which rod goes in which cyl as long as you look the #s up and use the right bearing. Rod bearings, main bearings, and thrust bearing (OEM) are going to cost around $200. Your also going to want to get all new seals/gaskets bottom and top end. HTH
