b16a2, 390 cc injectors 8 psi
Old Sep 20, 2010 | 06:11 AM
bboyjimpy's Avatar
Default b16a2, 390 cc injectors 8 psi
ok well during a street tune, my car's power gave out and for some reason i dont have any power anymore. after the street tune the tuner says that my injectors are maxed out. keep in mind that i am only running 4 psi at this moment with no boost controller. right now im running lean as *** when i accelerate ( car is barely accelerating) and im not hitting boost cause im running so lean. does this sound right to anybody? i heard i can run 390cc on 8psi and get 240 whp.
Old Sep 20, 2010 | 06:17 AM
300whpej's Avatar
Default Re: b16a2, 390 cc injectors 8 psi
why in the world would you use 390cc injectors on a boosted motor? your problem will always be not getting enough fuel, and its better to have more fuel than you need than not enough. how do you even run 4psi without a boost controller? i didnt think 4lb springs were made. you definetly need bigger injectors, and i wouldnt drive the car again with the ones you have now, unless you take the turbo kit off.
Old Sep 20, 2010 | 06:20 AM
bboyjimpy's Avatar
i bought 390cc injectors cause i was told it would hold up 4psi, i did have a boost controller on but i took it off.
Old Sep 20, 2010 | 06:23 AM
300whpej's Avatar
please scrap those injectors. look into some 450s, 510s, 750s, 1000s, etc. your injectors will ALWAYS hold you back.
Old Sep 20, 2010 | 06:53 AM
bboyjimpy's Avatar
oh yeah and im running a d series fuel pump...
Old Sep 20, 2010 | 06:58 AM
300whpej's Avatar
please tell me you're trollin'
jamesfawcett
Apr 13, 2010 01:33 AM
TurbodTegSfaria
Nov 14, 2006 04:07 AM
zbower7
Jun 12, 2004 09:12 PM
turbo*s2k
Feb 25, 2004 11:50 AM
ZygSpeed
Jan 2, 2002 09:44 AM
