Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Gas struts vs prop rod for hood?
Old Sep 20, 2010 | 04:30 AM
unclemoak's Avatar
Default Gas struts vs prop rod for hood?
I have a 2007 Accord SE with a 4cyl which obviously has a prop rod.
I was wondering if it would be possible to install the gas struts from a V6 model since it appears they use the same hood?
Old Sep 20, 2010 | 04:45 AM
MSchu's Avatar
My Name is Nobody
Default Re: Gas struts vs prop rod for hood?
sure it has been done. you'll need the strut and you will need to fabricate a bracket or cut one off of a wrecked chassis
Old Sep 20, 2010 | 08:20 AM
unclemoak's Avatar
Judging by some parts lists I've found on College Hills Honda's site, I think I might just need some ball studs.
Would someone mind taking some pictures of the gas struts on the hood of the V6, more specifically where they mount to the hood and inner fenders?
Old Sep 20, 2010 | 08:31 AM
MSchu's Avatar
My Name is Nobody
that ball mount is on the top end... on the bottom there is a tack welded "L" bracket... most of the prop ups don't have this and you need to fabricate one or buy a salvaged unit.
Old Sep 20, 2010 | 08:49 AM
unclemoak's Avatar
I see what you're talking about now. I looked at my car then compared it to a picture I found on ebay.
This is a V6 model where you can see the l bracket you were talking about.
Now I just have to figure out if I can get that to work on mine.
StayKrafty
Jun 29, 2011 08:34 PM
donaldadams
Aug 13, 2009 03:12 AM
cjmurillo
Nov 29, 2008 06:16 PM
EJ8 GSR-T
Jul 24, 2005 08:53 PM
mister2racer
Nov 21, 2003 07:57 PM
