Gas struts vs prop rod for hood?
I have a 2007 Accord SE with a 4cyl which obviously has a prop rod.
I was wondering if it would be possible to install the gas struts from a V6 model since it appears they use the same hood?
My Name is Nobody
Re: Gas struts vs prop rod for hood?
sure it has been done. you'll need the strut and you will need to fabricate a bracket or cut one off of a wrecked chassis
Would someone mind taking some pictures of the gas struts on the hood of the V6, more specifically where they mount to the hood and inner fenders?
My Name is Nobody
that ball mount is on the top end... on the bottom there is a tack welded "L" bracket... most of the prop ups don't have this and you need to fabricate one or buy a salvaged unit.
This is a V6 model where you can see the l bracket you were talking about.
Now I just have to figure out if I can get that to work on mine.
StayKrafty
06-29-2011 08:34 PM
