will this work on my S2K (offset)
i found some rims i wanted to buy, but i'm concerned about the offset on the front. would these rims fit, and what kind of tire would you recommend for the rims?
"Selling a set of Rota D2 wheels.
They have a bolt pattern of 5X114.3
They are 18X8 in the front and 18X9 in the rear.
I think the rear's have a +45 offset and the front's have a +35."
for the front i was thinking 205 40 18 to try and keep rubbing to a minimal
the rear i thought 245 45 18
thanks
thanks
I don't know about the offset. Hopefully someone else here can answer that part of your question.
You have to be careful finding rims for the S2000, because of the difference in center bore. The S2000 has different size hubs front and rear, and needs wheels which have the matching center bores.
That front size is a little small and the rear size is MUCH too large. The Tire Rack recommends 225/40-18 front (0.8 percent larger outer diameter than the stock 205/55-16) and 255/35-18 rear (0.7 percent larger than the stock 225/50-16).
